Bluetooth and Audi A4/Can't transfer address book
I just bought a new Audi A4 2009. I traded in a 2008 A3. My bluetooth connection via my blackberry was working just fine on the A3. But now I can't seem to transfer my T Mobile blackberry 8120's address book to the on screen display of the A4. When I try transferring the address book, I get something called no "object push server available?" It's something that has apparently changed in the Audi A4 2009 models because I had no problems with this with my Audi A3 2008.
Any thoughts?
Thank you.
Any thoughts?
Thank you.
My wife is having problems with her address book as well. Some of the entries show both name and number (in the car) but about half only show the number and completely miss the name.
I had a similar issue with my 3G iPhone. I had to delete all the recent made and received calls and then everything transferred over. Maybe try that?
I'm having the same problem as well. The phonebook transfers fine I suppose, but they are numbers only with no names (which IMO is pretty useless). I tried resetting the memory, reconnecting the devices and still no go.
My dealership told me to do the same thing when I tested out the MMI functions with my iPhone 3G on a recent test drive. I deleted all the recent calls (made and received) and the MMI picked up my contacts list in full after that.
Not sure if that would work for Blackberries or other smartphone type mobiles.
We did just that and no luck. The address book still appears just as it did. Is there any way to clear the car's memory while the phone out of range so we can start the process all over again?
http://www.audiusa.com/etc/medialib/cms4imp/audi2/aoa/company/owners.Par.0040.File.pdf<ul><li><a href="http://www.audiusa.com/etc/medialib/cms4imp/audi2/aoa/company/owners.Par.0026.File.pdf">http://www.audiusa.com/etc/medialib/cms4imp/audi2/aoa/company/owners.Par.0026.File.pdf</a</li></ul>
max90034
Q5/SQ5 MKI (8R) Discussion
20
01-02-2024 05:04 AM
NotoriousGLU
06-27-2017 06:40 PM
bradaudi
S6 (C7 Platform) Discussion
13
10-05-2015 06:38 PM
