Car won't start. No compression on motor.
Hi there.
Wondered if any of you had some suggestions regarding my problem. The thing is as follows:
Had my 1.8 tfsi since new, five years and one month to be exact, and one month over warranty as we have five years here in Norway. 59000km on the counter and served at intervals. The car have been working flawlessly all the time, with just minor bugs taken care of under warranty.
The other week i came driving home, parked the car, went in for a shower (30min) and the off to work. The car would NOT start. Cranking over just fine, a little to fine it seems. Searched my self for the obvious. Couldn't hear the puel pump prime, so wen't for it. Got it working again, but could only measure 6V in the power supply for the pump? Well, it primes and spins, but no start. Charged the battery on the car. Get 12.3 when fully charged, so maybe time to change. Try to jump start with no success.
Ended up towing the car to a local Volkswagen mechanic as there is 100km to the nearest Audi dealer. After 10 minutes he could tell me the problem. That flop flop sound from the exhaust should ring a bell, but it didn't. Well it seems there is no compression on the motor... The VW mechanic told me it would be better to move the car to the Audi dealer for further repair.
Have VCDS and could fetch som fault codes dating to the time the car died on me. Mostly electrical due to low voltage on the battery i think.
Afraid this could empty my savings account. Any ideas for a simple solution to all this?
Thanks for any reply.
The log:
Tuesday,22,October,2013,12:57:46:64789
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8KX9A065921 License Plate: DL96196
Mileage: 59640km-37058mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72
VIN: WAUZZZ8KX9A065921 Mileage: 59640km/37058miles
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (------CDHB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K1 907 115 M HW: 8K1 907 115
Component: 1.8l R4/4V TF H07 0002
Revision: A5H07---
Coding: 0104000C18070020
Shop #: WSC 00590 218 88632
ASAM Dataset: EV_ECM18TFS8K1907115M A01002
ROD: EV_ECM18TFS_AU48.rod
VCID: 387427B583AE9EDE6C3-806D
No fault code found.
Readiness: 1110 0101
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 030500
Shop #: WSC 06325 000 00000
VCID: 78F4E7B5CB2E5EDEAC3-802D
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x000C
Hex Value: 0xB98F
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x22A2
Hex Value: 0x0013
Hex Value: 0x028F
Hex Value: 0x00FF
01200 - ABS Valves Supply Voltage
000 - - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:23:19
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x02A0
Hex Value: 0x0034
Hex Value: 0x8193
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 A HW: 8K0 907 064 A
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030100
VCID: 2E5801ED79EA506E36F-807B
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:59
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0140
Revision: A1000000 Serial number: 0103.07.081452
Coding: 64000000
VCID: 70E4DF95A35E069E643-8025
1 Fault Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000170481
Coding: 2600D0914034AF000001000300001D0D0F1C03080001010100 0000
VCID: 30641F9563DE469E243-8065
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 270608 H06 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
6 Faults Found:
01516 - Terminal 30; Left
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:22:00
00927 - Terminal 30 (Right)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:21:00
00926 - Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:22:00
03123 - Terminal 30 - 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:22:00
03124 - Terminal 30 - 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:22:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:00
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 A HW: 8K0 920 930 A
Component: KOMBIINSTR. H16 0221
Revision: 00200000 Serial number: 991583378
Coding: 0F04080002000008010000
VCID: 2B5E08F94AF82546111-807E
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:59
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 7
Fault Frequency: 2
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.21
Time: 21:17:01
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G086298031
Coding: 000303
VCID: 4688594DF15AF82EEEF-8013
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:59
03041 - Energy Management Active
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 7
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:18:00
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007286154
Coding: 011C02204000410001
VCID: 3F864CA9AE80A9E6AD9-806A
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:23:14
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0112323174
Coding: 0100062000390040013001
3 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 24
Reset counter: 21
Mileage: 33473 km
Time Indication: 0
Date: 2011.06.20
Time: 14:47:38
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 38
Reset counter: 138
Mileage: 33875 km
Time Indication: 0
Date: 2011.06.28
Time: 14:51:48
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:59
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000164070
Shop #: WSC 00000 000 00000
VCID: 31621A9168D44F962BD-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Freeze Frame:
Voltage: 11.60 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 346C138557C67ABE40B-8061
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 C HW: 8T1 035 186 C
Component: Concert3 H02 0210
Revision: 00000004 Serial number: AUZ5Z6H1087077
Coding: 05020080010105000159070000
VCID: 3776248986B091A6659-8062
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:25:03
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007386186
Coding: 010C02204000210001
VCID: FF068CA96E00E9E66D9-80AA
3 Faults Found:
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Priority: 3
Fault Frequency: 20
Reset counter: 99
Mileage: 59356 km
Time Indication: 0
Date: 2013.10.11
Time: 14:32:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:23:14
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:23:17
The log:
Revision: A5H07---
Coding: 030500
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x000C
Hex Value: 0xB98F
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x22A2
Hex Value: 0x0013
Hex Value: 0x028F
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:23:19
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x02A0
Hex Value: 0x0034
Hex Value: 0x8193
Hex Value: 0x00FF
Revision: 00002001
Coding: 030100
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:59
Coding: 64000000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Coding: 00FD11
Coding: 025028
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:22:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:21:00
00926 - Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:22:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:22:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:22:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:00
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:59
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.21
Time: 21:17:01
Coding: 000303
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:59
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:18:00
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:23:14
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Reset counter: 21
Mileage: 33473 km
Time Indication: 0
Date: 2011.06.20
Time: 14:47:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 38
Reset counter: 138
Mileage: 33875 km
Time Indication: 0
Date: 2011.06.28
Time: 14:51:48
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:59
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Freeze Frame:
Voltage: 11.60 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1010
Coding: 0000004
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:24:58
Component: Display
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 08:25:03
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 20
Reset counter: 99
Mileage: 59356 km
Time Indication: 0
Date: 2013.10.11
Time: 14:32:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 99
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:23:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 59645 km
Time Indication: 0
Date: 2013.10.17
Time: 22:23:17
If you have no compression then you must have either slipped or broken the timing belt. That being the case you would have bent all of the valves which will require the head to be rebuilt and hopefully not need to replace any pistons. The Diag. codes don't mean to much if thats what happened. Are you sure he did the compression test correctly and the results were 0 compression on each cylinder? Good luck
carl viking
40
07-12-2024 02:45 PM
N'Syncro
33
02-16-2020 03:12 PM
