changing a tire
this is my first audi and i had a flat few days ago i wanted to get the tire of and replace it but i just used a fix a flat because when i took the lugs of and tried to get a tire of it didn't want to get off and all lugs were removed is there a hidden lug or something that keeps tire still on after you remove all lugs
Sometimes the wheel is just "stuck" to the wheel hub. Once the five lug bolts are out, just give it a good pop at the top and it should pop off (and be ready for it to fall). It doesn't take much, though.
You can always put a lug nut back on (loose) to keep the wheel from falling off.
calculi (12-04-2019)
yeah i used a screw driver as a crow bar and tug on it but it didn't get off i will have to change tires soon when i take it to tire place i will probably watch how he takes it off. but thanks anyway i bet you are right smac770 but i didn;t have patience to play with more
A6 Dan
21
01-09-2020 06:22 AM
John J Szobocsan
Chicago Discussion
03-20-2007 10:47 AM
St3phen
09-03-2001 12:49 AM
