curve xenons
#11
Mine are the self leveling/motorized kinda I guess. They do this top to bottom sweep when I start the car.
There's a screw on top that you can adjust to change the level also.. so you should be fine for Left or RHD... i don't know why the lights would be different.. mine are mirror images of each other.
Have you ever noticed a car which isn't symmetric?
RHD drive lights will work on a LHD car, but the beam pattern is opposite. LHD cars focus their light higher on the right side and lower on the left side (because of oncoming traffic). RHD cars focus their light higher on the left side and lower on the right side (because of oncoming traffic).
If you install RHD xenons and a LHD car you will either have to aim them ridiculously low, or blind oncoming traffic.
LHD beam pattern looks like. //
RHD beam pattern looks like. \\ (if that makes any sense
Bottom line: Don't use RHD lights, get the right lights for your car.
LHD = Left Hand Drive - (US, Germany, (most of Euorpe), etc.
RHD = Right Hand Drive (UK and Australia)
#12
Wow - this thread is filled with misinformation...
By symmetric I meant the shape of the car/lights.
The beam pattern is adjustable and makes no difference for LHD/RHD. Just use a phillips screwdriver and adjust.. Is that difficult?
#13
Anybody knows what the "Headlamp converter" setting in the MMI really does? Does it only block the higher part of the asymmetric beam or does it really convert the complete asymmetry ?
#14
#15
#16
Because of the different beam pattern for RHD, the Headlamp converter setting dips the lenses as to not blind oncoming drivers. This is intended for mainland Europe drivers entering UK and vise versa.
Just orderd Xenon upgrade..how hard is it to aim the headlights to get the correct lighting outcome?
Kevin@ECM
03-16-2004 10:29 AM
Dieselino (Jeff)
09-11-2002 07:44 PM
