does audi drive select adapts air suspension
hello , just wanted to enquire , does ads helps in driving in rugged pot holes or bad road conditions by lifting as per varied conditions. if yes , then which mode is best for bad road .thanx
hi, actually i have been facing lot of problems with the bottom of the car hitting speed bumpers even at lowest speed . donno wat to do . any suggestions ...thanx
नमस्ते
I have not read anything that allows you to set the ride height using Audi Drive Select. When my car's manual was printed the details of the individual setting were not finalized. I believe what they did was allow the three ADS systems (Via MMI) to be individually set to "Comfort," "Auto," and "Dynamic."
An example would be to set the Engine/Drive to Auto, the Dynamic Steering to Comfort, and the Suspension to Dynamic. Any of the three systems could of course be set to any of the programs. The settings placed in "Individual" would be remembered with reference to the key used when programmed.
Considering your situation, I wonder if a wheel and/or tire (tyre for our UK friends) change that increased the radius of the assembly could raise the car 25 to 40mm. This might spoil the aesthetics, and even have a detrimental effect on the Audi Drive Select, but I would hate to drag a car that cost well above 30 odd lakhs over a speed berm.
I faced the same situation while working in Bangalore recently. There were two speed berms that were just too high to hurdle, even driving dead slow. Not knowing where to register a complaint, I had our construction crew report to the location at first light on Saturday with a hired scraper and removed the offending material and hauled it away. It took less than ten minutes at each berm. I am such a bad boy, but the auto rickshaws were happy.
hello buddy , im in bangalore tooo.. facing lot of problems with bumpers here ... its ridiculous ...the road conditions are pathtic . the bumper hits the bottom so badly when car is loaded with 4 people . donno wat to do . ads seems to be useless in these road conditions , now regreeting should ve gone for q7. are u from blore ??
Hiya, I am a frequent visitor to India, but I'm a blue eyed American from California. I would certainly consider a tire wheel commbination to raise the ride height. At least until the city has time to manicure the roadways, some time in the next 1,000 years.
Jay337
Q5/SQ5 MKII Discussion
01-28-2018 11:18 AM
dparnas
Audi allroad
03-21-2008 01:39 PM
