:: ECS Tuning :: NEW!! B8 A4 2.0T Kohlefaser Luft-Technik Intake System
Audiworld Basic Sponsor
![](http://www.ecstuning.com/sales/ecs600header.jpg)
Crafted from hand-laid carbon fiber and utilizing a fiberglass interior layer, Kohlefaser Luft-Technik Intake sets a new benchmark in appearance and durability - all while resisting the performance-robbing effects of engine heat soak.
ECS has subjected this system to rigorous real-world testing, efficiency and power gain measurements on our in-house chassis dynamometer.
The convergence of unrivaled beauty, perfected fitment, industry-standard quality, and evidence-based performance claims has resulted in a gorgeous power-enhancer beyond anything available for your Audi.
The ECS Tuning Kohlefaser Luft-Technik Intake System features:
The Benchmark
Click HERE to order or for more information
![](https://www.ecstuning.com/marketing/Audi_B8_A4_ECS_KLT_Intake/images/Audi_B8_A4_ECS_KLT_Intake_01.jpg)
![](https://c1552172.ssl.cf0.rackcdn.com/769401_x600.jpg)
![](https://c1552172.ssl.cf0.rackcdn.com/732636_x600.jpg)
![](https://c1552172.ssl.cf0.rackcdn.com/769402_x600.jpg)
- Broader and smoother torque curve for an enhanced driving experience
- Gains of +4 WHP / +4 FT-LBS WTQ on APR Stage 1 ECU Upgrade
- Dyno proven increased engine efficiency
- Reduced intake restriction
- Reduced turbo outlet temperatures
- Reduced turbo strain: lower pressure ratio
- Reduced ignition timing retard
ECS Tuning's Kohlefaser Luft-Technik Intake System not only adds aesthetics and increased power output, but also allows your engine to run more efficiently. Due to the better flowing and more efficient intake design we were able to reduce turbo outlet temperatures by as much as 34°F at wide open throttle, and increase intake flow by 160% when compared to stock. This resulted in pulling equal amounts of power at lower boost levels and a more consistent running engine. Our testing showed that the stock intake was so restrictive that the ECU was pulling ignition timing and increasing boost to make up for the intakes inherently restrictive design. By carefully designing the intake, we were able to ensure that the ECU was not pulling ignition timing and producing power at lower boost levels. With the combination of increased ignition timing, reduced intake restriction and reduced turbo outlet temperatures, we were successfully able to design an intake system that overall outperforms the stock intake in every single way while reducing the stress placed on the motor.
Fits:
Audi B8 A4 2.0T (2009+)
Audi B8 allroad 2.0T (2012+)
Be sure to check out our -----> Installation PDF
Below are graphs showing how restrictive the factory intake is compared to ours an how much ours drops turbo outlet temps.
Turbo Inlet Restriction
![](https://c1552172.ssl.cf0.rackcdn.com/772572_x800.jpg)
Turbo Outlet Temperature
![](https://c1552172.ssl.cf0.rackcdn.com/772573_x800.jpg)
In summary we were able to reduce turbo outlet temperatures by as much as 34°F at wide open throttle, and increase intake flow by 160% when compared to stock. This resulted in pulling equal amounts of power at lower boost levels and a more consistent running engine. Our testing showed that the stock intake was so restrictive that the ECU was pulling ignition timing and increasing boost to make up for the intakes inherently restrictive design. By carefully designing the intake, we were able to ensure that the ECU was not pulling ignition timing and producing power at lower boost levels. With the combination of increased ignition timing, reduced intake restriction and reduced turbo outlet temperatures, we were successfully able to design an intake system that overall outperforms the stock intake in every single way while reducing the stress placed on the motor.
Jason
Jason
ECS Tuning-Audi
01-04-2016 08:08 AM
ECS Tuning-Audi
12-22-2015 09:54 AM
ECS Tuning-Audi
11-20-2015 01:25 PM
ECS Tuning-Audi
11-19-2015 06:34 AM
ECS Tuning-Audi
09-18-2015 08:08 AM
