EPC and CEL + power loss and shake.
car:2012 2.o tfsi 8speed quatro.build date11/11 900 miles.
We took delivery last week.Using shell v-pover only.
Today after 45 min drive,when pulling out from traffic light i see
EPC on and CEL flashing plus loss of power and shaking like missfireing .I pulled over shut it down and waited for 2 min.After starting and driving for 1/2mile same happened,so pulled over and called for audi road assistance.They towed it to my dealer.I,m going there in the morning to pickup loaner and see what they say.
I did some reading about epc,cel but all that seems to be from at least a year ago.No current problems?
What you think?ideas?
Thanks in advance.
I will keep you posted.
Bart
Thanks in advance.
Bart
Thanks in advance.
Bart
Thanks in advance.
Bart
Hope it helps.
Dealer called this evening and told that there was a misfire and that they replaced one fuel injector.I will pick up the car tomorrow and find out exactly what was wrong.
So i finally had a chance to read my service ticket.This is what they did:
cylinder #1 misfire fuel injector mechanical malfunction.perform GFF swap #1 and #2 spark plug #1 and #3 coil pack,road test,misfire stays on #1.perform compression test 180 psi @all 4 cylinders.remove and inspect intake manifold.remove and replace fuel injector #1.rebuild remaining 3 injectors,road test ok.
Im no mechanic but i think that it is a lot of stuff going wrong on 900 miles car.Now car drives just fine but im a little afraid to step on gas pedal to hard.I guess i just put it in sport and step on it and see what happens next.
What are your thoughts guys ?
I definetly dont want to be affraid to drive my car a little hard.
Sounds pretty minor overall. I'd consider it a hiccup.
You should not feel uncertain about your car. Go out and get on it (safely) until you feel confident that the problem is fixed. Babying it to avoid the problem will not help you find out whether the problem was fixed.
I'm sure it was but best to go give it a proper "test".
I'm sure it was but best to go give it a proper "test".![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
Well here is the thing: i was "using"the car when problem emerged. So that is why i'm a little worried.I will "use " it again this sunday morning on a nice twisty road not far from my house,just to reassure myself that it was a good choice to buy it.
I really like this car a lot,and we plan to keep it for at least 5 years,so that "minor hiccup" at 900 miles got me worried.
My autox season starts in may so the car will be "tested"for sure.
Thanks for your replies.
