Faults, 03110 - Active Steering Control Module (J792) 004 - No Signal/Communication
Hello all
New member here.
I have a 2015 A4 2.0T FSI and recently enabled hidden green menu, then ADS and a handful of other convenience features.
In Vag-Com while coding to enable ADS, in 09-Central electric, in Byte 7, I selected bit 5 Audi drive select, then decided to select Bit 4 dynamic/Active steering installed without confirming I actually have active steering...
After scanning for any faults, I recieved the following errors:
09-Cent. Elect. -- Status: Malfunction 0010
ADS, 03110 - Active Steering Control Module (J792)
Went back into 09-Cent. Elect Byte 7 and deselected bit 4 dynamic/Active steering installed, saved and restarted the MMI.
returned to 09-Cent. Elect Byte 7 to see if changes were saved only to see bit 4 was enabled again...
Entered the original long code I saved before enabling ADS but code does not stick after saving.
Can these faults be ignored?
I have no issue with any coding I have done thus far?
I would really prefer not to completely revert and start over.
Please advise and thanks.
New member here.
CFLQTRO
Q5/SQ5 MKII Discussion
21
06-07-2024 08:27 AM
462tony
VAG-COM Discussion
06-12-2019 12:27 PM
