FI: Headlight levelling problem
I got a headlight corrector error: "1535: Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle. Possible decryptions (note control module): Audi Submission of a control signal to the right-headlight-V49 corrector actuator motor; Control for servomotor headlight range control right-V49"
So I tried to locate the light level sensors, but it seems there is no sensors at front at all. I don't understand that because everywhere is shows that they should be on the lower support arms. Where can I find them?
I can't interpret that error message. Do you have a more normal complete scan log such as from VCDS?
What is your actual car? What model year? Is this a new problem on an otherwise factory vehicle? Or are you messing with the headlights?
bjwhite
01-05-2006 11:27 PM
