Heated Mirrors
Oh, how can you tell if they are on? You can rest a temperature sensing organ against it and see if it feels good? I figured that they were on when it was 20F out and the mirrors were clear. Not very scientific, I know.
This one is funny because there was those whole debate back in the day about the round switch on the drivers door for toggling between left, center (heater) and right mirror settings (I still believe someone when they said not to depress this button, try it does, because it's an auto eject button!).
If turned to the left mirror it does NOTHING. If turned to the right mirror (assuming you have this functionality) it pivots the right mirror down to curb level for parallel parking "when you are backing up" (in my opinion it needs zoom because it's a bit difficult to make out the curve to rim distance and trajectory on such a small mirror - maybe the least used function on my car). But center **** setting is the sweet spot. According:
to other posts the heater is ON when in this setting. The manual seems to confirms that so it would suggest by leaving it here you'd greatly reduce the life time of the heater as it is ALWAYS on. I had it set there for a while after purchase (I had no clue the thing came with mirror heaters in Scottsdale freakin AZ!!!) so I read a post that got into this subject and learned that I need to leave it to the left mirror setting to avoid doing anything (wife freaks when right mirror pivots to curve position during backup - she just does not like it, bothers her if you know what I mean).
So bottom line is that there is no indication heated mirrors is activated and you pretty much have to find out by reading your manual or checking the forum (like my lazy *** did)...
I iced up the driver's mirror really badly after washing the car once this winter. Found the water had left spots on the mirror when it dried, too many for my liking, so what did I do? Tried going over it with a wet chamois. Well that didn't work too well in the extreme cold. A layer of ice was just caked on there. Only when I PRESSED THE BUTTON did the ice start to break up, and in about a minute most of it had melted and/or fallen off the mirror. Quite impressive, actually. A bit of ice was left around the edges, indicating that possibly the heater was only on for about a minute after I had pressed the button and the heating cycle had ended. So, unless you're stacking weights on top of the button and keeping it permanently pressed, I don't think the heater's life time will be reduced.
I saw that you could press the mirror adjustment button in. I guess this activates the mirrors. I'm old fashion and would like a little red light to go on to confirm activation. Thanks for the info. I guess I'll have to wait untill the winter to try this out. Hopefully!
Are you sure? Just that manual says if you leave the **** in the center position the heated mirrors activate when the temperature outside is cold enough. There's no mention of pushing the button in to activate.
Maybe it was a coincidence in your case that pushing the button in was the same time the mirrors kicked in because it was cold outside?
FWIW, I called AOA and they told me the mirrors act as stated per the manual - the heaters come on in the center position - pushing the button IS required to activate the heating elements (my manual didn't mention this, as I recall though she said it was in the manual she was referencing).
She said it is time based but also a protection circuit will shut them off automatically if the elements get too warm to protect the heating wires from burning out prematurely. I was told they work much like the rear defroster heating element.
