Help, car shuts off while coming to a stop
I have manual a4 b8 quattro 2.0t, check engine light was already on but EPC light came on and then would go back off. Have done a lot trying to figure this out and cannot find the diagnostic, doesn't have a rough idle or anything, car trys to turn over after stall and sometimes it will start right away and sometimes it takes a couple trys. Please help, here's the list that came from my VCDS. I did notice the engine control module but haven't got too much into electrical with this and am unsure if that will help. Thanks, all the help the better. ( figured just copying the whole list would make it easiest )
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AA HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H16 0003
Revision: E1H16---
Coding: 0104010A180F0160
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TFS8K2907115AA A01004
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 6E85C7AA601FB2CB6DF-803A
3 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 195628 km
Date: 2021.05.06
Time: 16:33:31
Engine RPM: 763.50 /min
Normed load value: 9.4 %
Vehicle speed: 0 km/h
Coolant temperature: 43 °C
Intake air temperature: 17 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 13.853 V
Unlearning counter according OBD: 37
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 195628 km
Date: 2021.05.06
Time: 16:33:35
Engine RPM: 756.00 /min
Normed load value: 9.8 %
Voltage terminal 30: 13.876 V
5664 - Mass Air Flow Sensor (G70)
P0100 00 [096] - Supply Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 195628 km
Date: 2021.05.06
Time: 16:33:31
Engine RPM: 764.00 /min
Voltage terminal 30: 13.782 V
Readiness: 0010 0101
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Revision: -------- Serial number: --------------
Coding: 070D10
Shop #: WSC 02391 823 56573
VCID: 7AADFBFA2CD7EE6BC17-802E
4 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 11
Reset counter: 149
Mileage: 194722 km
Time Indication: 0
Date: 2010.02.20
Time: 11:25:05
Freeze Frame:
Hex Value: 0x2000
Hex Value: 0x4006
Hex Value: 0x1226
Hex Value: 0x469F
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 150
Mileage: 194722 km
Time Indication: 0
Date: 2010.02.20
Time: 11:25:06
Freeze Frame:
Hex Value: 0x2700
Hex Value: 0x6206
Hex Value: 0x1232
Hex Value: 0x029F
Hex Value: 0x00FF
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 195328 km
Time Indication: 0
Date: 2021.04.22
Time: 13:09:06
Freeze Frame:
Hex Value: 0x3B00
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x1BAA
Hex Value: 0x00FF
03015 - ASR/ESP Button (E256) jammed
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 135
Mileage: 195382 km
Time Indication: 0
Date: 2021.04.23
Time: 13:58:37
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x48A2
Hex Value: 0x0036
Hex Value: 0x01AE
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DF HW: 8K0 907 064 DF
Component: BCM2 1.1 H02 0326
Revision: 00002001
Coding: 0B0100
Shop #: WSC 02399 823 56573
VCID: 77ABE2CE1FC5F303BE9-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000070220020
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000092405010
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN
Component: KLIMA 1 ZONE H08 0171
Revision: A1000000 Serial number: 01291120091144
Coding: 64002000
VCID: 7DA7F0E63DF9D953E45-8028
2 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 123
Mileage: 189434 km
Time Indication: 0
Date: 2009.06.26
Time: 01:11:05
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 123
Mileage: 189434 km
Time Indication: 0
Date: 2009.06.26
Time: 01:11:05
Freeze Frame:
Temperature: 26.0°C
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000523900
Coding: 690000B1063C00010000080300007F5F0F1412080000002100 0000
VCID: 3C213DE26663105B93B-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 241109 H06 0070
Serial number: SWF09110245275
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AK HW: 8K0 941 531 AK
Component: E1 - LDS H08 0090
Serial number: 00000000001711090554
Subsystem 3 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
1 Fault Found:
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 123
Mileage: 189439 km
Time Indication: 0
Date: 2009.06.26
Time: 01:36:00
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H39 0560
Serial number: 003EGD05AA8-
Coding: 303836354230303030304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 42DD431A040766ABD97-8016
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R09000029XS
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4E130673B
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME4D62445CO
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME174521221
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME0F451822F
Crash sensor for front airbag: driver side:
Serial number: 63732SME40444D02U
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME3B442B34%
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IL100096
Coding: 000014
VCID: 3D2730E67D791953A45-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 E HW: 8K0 920 950 E
Component: KOMBIINSTR. H20 0255
Revision: 00100000 Serial number: CIM357PC9
Coding: 8B1009000300D705020000
VCID: 313F1CD6B121ED3330D-8064
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G09B27806A
Coding: 00C303
VCID: 50F97952DAEB843B5F3-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 1909CA97171109
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0280
Revision: 00000000
Coding: 020302
VCID: 392F24F66951257388D-806C
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 135043 km
Time Indication: 0
Date: 2016.07.06
Time: 13:14:02
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Revision: E1H16---
3 Faults Found:
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 195628 km
Date: 2021.05.06
Time: 16:33:31
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 195628 km
Date: 2021.05.06
Time: 16:33:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 195628 km
Date: 2021.05.06
Time: 16:33:31
Coding: 070D10
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 149
Mileage: 194722 km
Time Indication: 0
Date: 2010.02.20
Time: 11:25:05
Freeze Frame:
Hex Value: 0x2000
Hex Value: 0x4006
Hex Value: 0x1226
Hex Value: 0x469F
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 150
Mileage: 194722 km
Time Indication: 0
Date: 2010.02.20
Time: 11:25:06
Freeze Frame:
Hex Value: 0x2700
Hex Value: 0x6206
Hex Value: 0x1232
Hex Value: 0x029F
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 195328 km
Time Indication: 0
Date: 2021.04.22
Time: 13:09:06
Freeze Frame:
Hex Value: 0x3B00
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x1BAA
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 135
Mileage: 195382 km
Time Indication: 0
Date: 2021.04.23
Time: 13:58:37
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x48A2
Hex Value: 0x0036
Hex Value: 0x01AE
Hex Value: 0x00FF
Revision: 00002001
Coding: 0B0100
Coding: 64002000
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 123
Mileage: 189434 km
Time Indication: 0
Date: 2009.06.26
Time: 01:11:05
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 123
Mileage: 189434 km
Time Indication: 0
Date: 2009.06.26
Time: 01:11:05
Freeze Frame:
Temperature: 26.0°C
Coding: 00FD11
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 123
Mileage: 189439 km
Time Indication: 0
Date: 2009.06.26
Time: 01:36:00
Coding: 000014
Coding: 00C303
Revision: 00000000
Coding: 020302
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 135043 km
Time Indication: 0
Date: 2016.07.06
Time: 13:14:02
Freeze Frame:
Fault Priority: 6
You need to fix that MAF issue. It has the ECM unhappy, which makes the ABS/ESP unhappy. But it lists it as intermittent. Clear DTCs and see what comes back.
ESP button on the dash is jammed? Is this error expected? When you press the button, does ESP trigger between off and on as expected?
"B8", ok, so it could be a MY09-MY16 A4, MY08-MY17 A5, or MY09-MY17 Q5. :-) We figure it's an A4 since you're here, but what's the actual model year? I'm guessing MY10-MY12 since I don't see a tire pressure control module in your module list.
Have you looked to fixing the G395 error? Device on the front left of the radiator with a plug in it? Thing is not an uncommon problem on the B8.0, but it could be the sensor or the wiring to it. Still, it's a relatively cheap and pretty easy thing to replace. Is your A/C working otherwise?
Your scan log is truncated. You have errors in 42, 46, and 56 that are not posted.
boneyxy
Audi A5 / S5 / RS 5 Coupe & Cabrio
11-30-2020 02:25 PM
Mike Freeman
13
10-29-2020 03:17 AM
Jessyjey
S4 (B8 Platform) Discussion
09-24-2020 10:17 PM
WODT-Sanders
4.2 V8 Discussion
06-15-2019 07:46 PM
