How do you stream music via internet on Iphone?
I have a 2009 A4 Premium Plus and have the Iphone cable. Works great for phone and MP3 slection on dash (though menu organization could be better). I would like to also stream internet music. Do I need a seperate MP3 cable to do this? Which one should I use? I assume if I replace the Iphone cable with the MP3 cable I will still have use of the phone through the bluetooth.
FYI for those who plan to updated their Iphone (mine is a 3G) to the most current operating software (version 4.0.**), I had to resync my phone to the car. Never needed to do this with previous upgrades, Pretty easy to fix, just go into settings on Iphone while in the car and add the pin number again.
My workaround was pretty simple - bring one or more MP3 files with silence into the ipod under "A" so it's the first thing on the list. play the files through MMI, repeat track or folder. Then, you can simply launch Pandora, NPR music, Last.FM, or whatever internet radio option you choose and you're set.
Not sure I understand. Are you basically saying listen to a silent mp3 song, set to repeat and then multi task with Pandora or something like that?
Also, one other advantage I found with the new version on the Iphone. I no longer have that annoying loud ring when someone calls me. The ring now is the normal ring I have set up on teh Iphone.
You MAY also be able to work around it if you could force the iPod/iPhone to pause playback but I have iOS4 with multitasking disabled, so I'm not sure if the popup controls through multitask utility (dbl-click home, etc) may be another way around it.
If you are running version 4.0 of the iphone IOS, start playing a tune from iTunes, then while connected launch Pandora or Last.fm either works fine. It will stay playing now. Though the dash will show that the itunes song is still playing but the itunes time counter will pause. Works every time.
Chris Brookes
11-15-2016 01:33 PM
