A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Interior fan noise
Old 06-25-2010, 10:31 AM
  #11
BMWBig6's Avatar
If these were high-mileage cars, I'd suspect worn commutator bushings (if they even use those in modern vehicles anymore), especially if they only did that at certain fan speeds and not others.
Old 09-12-2015, 06:15 AM
  #12
evandro's Avatar
Default q7 problem
when i turn my engine on, even on cold start, there is this noise, like a fan noise, humming noise that stays on for ever, until i turn the engine off, i am super worried and please someone help.
Old 02-20-2021, 11:35 PM
  #13
Teapotkid's Avatar
Not sure if this will help but I had a similar problem in my Audi A4 B8... I took the glove box out I turned on the car and went through the various fan speeds, at the same time running my hand around to see could I feel air coming from anywhere.. sure enough I found the filter housing was loose, so i secured it again and 'hey Presto' problem solved, went for a drive and no more annoying whistling... only took me about 25mins from start to finish with a small 8mm socket/ratchet to remove the glove box... best of luck!
98Quattro
11-23-2011 06:55 AM
mness
07-28-2003 02:16 PM
Driver8
07-15-2002 08:24 AM
Sam2000
02-10-2002 05:07 PM
Samantha
12-28-1999 07:03 AM
Quick Reply: Interior fan noise
