IPOD Jack in Glove box
#21
According to the A5oc web site, some people claimed to have connected 500Gb drives, but it seems that the limitation is 4000 songs. This would take about 200Gb in wave. Drives smaller than 320Gb are hard to find these days !
Something else that is interesting is that the Ipod AMI cable is supposed to take the analog output of the Ipod, when you connect a hard drive, you get the digital output and use the dac of the radio which some claims to be of better quality.
I do not have the "real MMI" in my car, I have the radio "pseudo MMI" so I wonder if the limitation of the number of files that can be accessed is the same...
Hopefully the cable I ordered from e-bay will not take a month before showing up !
#22
#23
I just received my AMI USB cable from China today and bought a 320Gb pocket drive from Buffalo. I formated the drive in FAT 32 and copied several directories with different audio formats to see which ones would work: AAC, MP3, WMA, WAV, FLAC. None of them would work from the drive. The AMI said: unsupported device !
I copied only the WAV and the WMA directory on a Kingston USB stick and the AMI saw only the WMA files, but did not read any Metadata. The same files on the SD card were displaying all of the metadata info of the files: Artist, song, album and the info menu was also showing the genre, year and commentary !
You say you use uncompressed audio file, what format are you using ? Does it read the metadata of the file ? What brand of hard disk are you using ?
I do not have MMI, just the radio MMI style menus, maybe you have the full MMI and this is why yours is working ?
It seems I could probably use WMA, MP3 or AAC. I have to do more tests to see if the metadata in any of those is supported.
Thank you for your help.
#24
I need some help Kal !
Kal
#25
I had a 40Gb pocket drive, but it crashed when started to load files on it :-(
I just tried different file formats and MP3 supports the Metadata, so MP3 320 Kbs it will be !
I have to try another brand of hard disk or a solid state disk or a large USB stick.
Thanks,
Pierre
Thanks,
Pierre
greginfinity
22
02-09-2015 08:47 AM
jfischetti
9
02-07-2011 12:23 PM
