Latest Low Speed Shudder Update (and high speed vibration TSB#)
#21
Getting a new steering hose replaced this soon? You must be at one of the dealers AOA selected to field test it (I heard that they are field testing in California?). The rest of us will have to wait a few weeks longer for the new parts to be manufactured and sent to our dealers.
#22
No offense intended, but you've been worrying on this for a few weeks. If the cost of an alignment vs. warranty is the bottom line issue bothering you and the dealer won't help, as I've suggested in the past, call AOA yourself and escalate if necessary - that's what I've done successfully for other issues. Agonizing over it here isn't going to resolve it for you.
#23
Indeed - I have been in contact with AoA since the issue started and Brad over there was kind enough to get me in early on the list for the first limited batch of hoses.
Sit Rep:
High speed shudder with the new control arms/bushings is gone - drove 230 miles today and did not feel it once. Car feels more "planted" too and while you can feel the imperfections in the road, you do not feel the shudder at speed.
As for the steering hose, I'm not completely convinced...
While it does not do it under normal slow speed maneuvering any more, I'm still able to reproduce the problem if I turn the steering wheel fast in a turn - think of a hair pin 180 degree turn doing 15-20 miles and hour. I will be speaking with Brad on Monday to update him. If I continue to feel it as I test it around town, I will certainly be pursuing the issue further.
Sit Rep:
#24
Sit Rep:
Sit Rep:
I've got over 1500 miles on my new control arms and am experiencing the same result - no more high speed steering wheel vibrations. Completely gone.
As for the low speed "shudder", I have never noticed it at any time except intermittently at under 5 mph in a turn on certain types of surfaces like painted concrete or gravel covered asphalt. I've never experienced it at any speed above 5 mph in any situation nor have I read this in the forum posts. If yours does it at the higher speeds, I wonder if you have a different issue resulting from the new hose. Did also you get the steering shudder at 15-20 mph prior to the hose swap?
#25
Yes - had the problem anywhere between 1 and 15 mph - less so at higher speeds - but it still happened a few times.
Ill be thoroughly testing it out over the next few days and get back to everyone.
95wildtt
9
09-28-2015 04:08 AM
CPLYONS
09-07-2015 07:19 PM
Touge.ca
Canadian Discussion
09-02-2015 01:30 AM
Touge.ca
Canadian Discussion
09-02-2015 01:28 AM
