Like to install 18 X 8.5 wheels with 255/40 Tires
I know that 18" OEM wheels are 18 X 8,I believe the offset ranges between 43 and 45.
If you install 19" OEM wheels the measurements are 19 X 8.5,I believe the offset is 45.The tires on these wheels are 255/35.I would like to know if I could install 255/40s on wheels that are 18 X 8.5 with a 45 offset???
I don't see why not. The 255/35-19's on a 19x8.5 +43 S-line wheels fit fine, so you should be right about the same diameter, width, and location. This is always helpful to compare:http://www.rimsntires.com/specs.jsp
Small Town Terrorist
09-14-2008 02:42 PM
EGainer
A4 (B7 Platform) Discussion
9
12-11-2007 05:59 AM
peanutome
08-07-2004 10:23 PM
