MMI hidden green menu + rear sensors graphic display
I have rear reserve sensors and nav but NO camera or front sensors.
When I reserve I only get the audible tone, no graphic display on the MMI screen.
Does anyone know if it's possible to enable the graphic display via the hidden green menu instead of needing to find someone with Vagcom that knows how to do it?
Since also in VCDS (VACcom) you have to enter a security code, I doubt that it can be done in the "green menu". It also depends on the model year you hve since the coding that I used and is found on internet is for module 10 which, I think, only exists in pre-facelift cars.
Lastly the parking sensor control module needs to be of a revision that supports graphics (so maybe not the first B8 model years).
(You need VCDS also to enable the green menu, but I guess someone did that for you already..)
jfischetti
Q7 MK 1 Discussion
07-16-2008 10:35 AM
