A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Old 08-23-2016, 03:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B8) Electrical Guides
Print Wikipost
oem spark plugs
Old 10-25-2010, 06:36 AM
userbbc's Avatar
Default oem spark plugs
So about time to change the spark plugs (35k mi). Can someone confirm the part number and brand of the oem spark plugs?
The B7's used Bosch but the dealer now states our B8's use NGK. Got an incorrect part number from the dealer for the NGK's so having a hard time sourcing the oem's.
Old 11-06-2010, 11:44 AM
lanwiz1's Avatar
BKR6e
Old 11-17-2010, 04:38 PM
takethetest's Avatar
Originally Posted by lanwiz1
BKR6e
On the NGK website it says that "BKR6e" is a "V-Power" plug. They are $1.98 on a website I found. Are there any better plugs? Would better plugs make any difference?
Old 11-22-2010, 02:50 PM
lanwiz's Avatar
bkr6eix Iridium plugs.
If your car is chipped then use bkr7eix
Old 11-22-2010, 05:18 PM
Do you think its worth the extra money?... Whether I chip my car or not.
Old 11-27-2010, 05:24 AM
ernestolopez's Avatar
So what is so special about these Plugs?...If the car is Chipped?...Just curious!
Old 11-27-2010, 09:10 AM
ThePiombino's Avatar
Would love to hear the reasoning for this as well. My car is chipped and has been picking up some misfire DCTs as of late and was wondering if the plugs could be the reason...
Old 11-29-2010, 07:10 AM
lanwiz1's Avatar
EIX plugs are Iridium, which would make them last longer, the E is a copper plug, copper is a better conductor but it is soft and will burn out faster so you need to replace every 35000 miles, Iridium may last double and is less subject to carbon deposit, better self cleaning.
Old 11-29-2010, 07:14 AM
lanwiz1's Avatar
It is all up to you if you want to spend the money, the performance difference is minimum but the iridium last longer then copper.
If your car is chipped you can use BKRX7E or EIX because this plug runs a little colder then the 6e or EIX, Chipped cars runs hotter so this may help keep temp down and prevent plug melt down.
Old 11-30-2010, 02:56 PM
Former Vendor
Gavin-AudiUSAParts's Avatar
The B8 A4 2.0T does in fact use an NGK plug (part no. 06H905601A).
Quick Reply: oem spark plugs
