oil extraction through dipstick tube
#12
If you use the extraction device, you will get all the oil out. If you can't get all the oil out, your doing it wrong. I've seen it any many shops already and the techs that know how to use it say the same thing. You have to use the plastic tubes and insert it correctly into the tube. If you insert it too far, it will curve back upwards off the bottom of the pan.
#14
But how does that alow to take out more oil than just by draining? The drain opening is at the lowest level of the pan so that everything flows towards it. Unless there are pockets were the oil gets trapped and that can be gotten to by the extractor, I still don't see how you get more oil out with an extractor.
#15
