A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Old 08-23-2016, 10:46 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B8) Lighting Guides
Print Wikipost
Phillips X-treme Ultinon LED Fog Light Lamps
Old 06-02-2015, 07:14 PM
E92MPower's Avatar
Default Phillips X-treme Ultinon LED Fog Light Lamps
I wanted to upgrade the OEM halogen lamps to better match the headlights. I spent a good bit of time researching the the Phillips Ultinon lamps, but couldn't find much information on them. I also considered the Piaa, V-LED and other brands but wasn't impressed with their desgin or turned off by the their hefty price. I took a leap of faith and pulled the trigger on the Phillips X-treme Ultinon LED fog light lamps at $150 bucks they aren't cheap and have less lumens, but compared to the Piaa's at $300 they're a bargain and have a longer warranty.
I had the following goals in mind:
-Get as close as possible to the cool white/blue OEM LED DRL headlight color.
-Avoid the 'coated" bulbs like the Ziza or Silverstar options that not only produce less light, but IMO cheapen the look of the foglight lens.
-Avoid LED lamps with external fans or HID's.
-Produce similar or better light output than stock.
-Avoid throwing any codes.
I acomplished all of them and very happy with the results. Keep in mind I'm not a proffesional photographer and tried to capture the most accurate comparison by playing with the ISO. As a side note, I didn't photoshop or edit the photos in anyway. Enjoy!
Packaging
http://Name:  IMG_1089.jpg
OEM v.s. Phillips Ultinon LED
Installed
http://Name:  IMG_1105.jpg
http://Name:  IMG_1140.jpg
Phillips on the left and OEM on the right.
http://Name:  IMG_1059.jpg
http://Name:  IMG_1092.jpg
Close up of Phillps LED
http://Name:  IMG_1047.jpg
Fog Lights Only.
http://Name:  IMG_1097.jpg
Headlights and Foglights
http://Name:  IMG_1114.jpg
Night Front
http://Name:  IMG_1118.jpg
Bonus LED interior!
http://Name:  IMG_1135.jpg
Very pleased with the puddle light output
http://Name:  IMG_1148.jpg
Gave the M's interior a little LED conversion too!
http://Name:  IMG_1145.jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 06-13-2015, 08:15 AM
jacobkbhs's Avatar
What Leds are you using in the puddle lights? Looks amazing
Old 06-15-2015, 04:55 PM
E92MPower's Avatar
Thanks! I wasn't impressed with the ECS/Zizza bulbs so I went with my trusty VLED Flank bulbs in 6k. Much brighter than the Zizza bulbs. The OEM housings have poor light output so I needed to do something.
Also, my garage floor is epoxy coated so the LED's really pop.
Old 06-23-2015, 02:51 AM
TinyRK's Avatar
So those Philips don't throw any codes? Nice
Old 06-29-2015, 01:58 AM
E92MPower's Avatar
No codes and light output at least comparable if not better than the OEM halogens.
Old 09-30-2015, 03:08 AM
Jedinyte120's Avatar
Those LEDs look nice. Did they make the glass housing hot to the touch? Hot enough that it would crack if they were used as DRL and water got splashed on them after being on for a while? I plan on setting my fogs as DRL. Thanks
Old 10-04-2015, 03:43 AM
E92MPower's Avatar
The fog light lens is plastic and I've driven in the rain several times with them on without issue. I haven't had any issues with the lens discoloring or crazing like I have with my trucks fog lights when I changed them to HID's.
Phillips LED's are a bit pricy but are a great option.
Old 10-13-2015, 02:28 PM
michaelbeccio's Avatar
Do you have a link to purchase those Philips LED bulbs? They look great; how difficult was installation? Same bulbs for the flood lights too?
Old 10-15-2015, 05:43 AM
E92MPower's Avatar
I'm a bit confused with your question. The interior lamps and fog lights not floodlights were both switched to LED's. The interior was from 2 different manufactures; VLED and Ziza from ECS Tuning. The performance/lightoutput from the Ziza bulbs were poor so I made some changes using bulbs from VLED.
The fog lights are Phillips. Install was super easy.
Let me know if you have any other questions.
Old 11-17-2015, 06:30 AM
Samir Farooq's Avatar
Default Fog bulb type
Hi!
Can you please tell me what kind of bulb you used for your fog lights?
I know they are LEDs and all but I want to know if they are H8 or H11 or something else?
Thanks in advance, hope to hear from you.
Quick Reply: Phillips X-treme Ultinon LED Fog Light Lamps
