"Please Drain Oil"
#11
Update:
Called my dealer and he felt the oil level might have been just a bit too much triggering the sensor. After driving about a hundred miles or so, the message no longer appears indicating I may have burned off a bit of oil causing the sensor to no longer trigger.
HE told me if it comes back, they'll check the sensor.
#12
Update:
Did yours show up again after 100 miles or so? I don't care if it's slightly overfilled as long as it won't damage the engine.
#13
Not sure when it showed up after the 5K oil change. I can report that after a couple of hundred more miles, the message has now gone away. The dealer says it can happen with just a tiny bit over but nothing to worry about. Should go away on its own after awhile.
#14
...overfilling oil may damage your catalytic converter so you need to drain the excess immediately.
Unfortunately damage may only appear years down the road - often when the converter fails shortly out of warranty...
#15
Or in my case...fortunately since I'm almost a year in to a 3 year lease. I'm going with snagitseven and just burn off the oil. If the message is still there after driving a few more hundred miles I'll call the dealer.
#17
...the issue (damaged cats) will rear its ugly at around 90/100k miles when your converter dies a horrible death.
Overfilled oil is a leading cause of premature conferter failure - they are designed to last upwards of 200k miles...
#18
2.0T engine spec is 4.9 quarts of oil. This is simply asking for trouble since most places will simply dump 5 cans in. Who on Earth is going to measure 0.1 quarts of the last can?
#19
Also is 0.1 quarts of overfill really going to cause that much damage?!
#20
Just wanted to follow up on this, I checked my oil yesterday and it now shows the gauge and it's 100% full. So story is if you see a "Please drain oil" after your 5k or other oil changes, just ignore it.
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
