rough shifting from 1st to 2nd and 2nd to 1st
On a brand new 2010 A4 with the Prestige package I'm noticing the following.
1) rough shifting from 1st to 2nd at slow speeds
2) rough shifting from 2nd to 1st when applying the breaks at a stop
problem does not happen at higher RPMs or in Sport mode.
If I manually shift tiptronic driving in say a parking lot at > 1,000 RPMs problem is very noticeable. Car hesitates and almost lunges forward as if the transition from 1 to 2 is not well coordinated.
Problem seems to happen after a warm start, and on a cold start since the engine revs higher before shifting it's not as noticeable.
All other gears are very smooth.
Thoughts?
Thoughts?
Anyhow, I stopped by my dealer today and the foreman drove around with me and witnessed the issue. I'll be in for service on the 18th to hopefully have it fixed.
OP, I know exactly what you are referring to. I actually experience the same issue on my car. I would say if the shift (1st to 2nd) happens at or near 2,000 rpm, it's much smoother.
From 1st to 2nd, I wouldn't call it "rough" but you can definitely feel some sort of bumping sound/feel, whatever you call it.
I've raised this issue with the dealership before and they just said there is nothing wrong with it. Please let me know how your experience with your dealership goes. Maybe, if they find something and fix it, my dealership will more likely to do the same if I point them in the right direction ...
What model year car do you have?
I can tell you that the A4 I test drove did not have this problem and the foreman said it wasn't normal.
For me it's equally bad going up and down. When I come to a rolling stop, i can really feel it. The foreman mentioned that it's almost like the car is confused about what gear it should be in.
[QUOTE=shahineo;23894619]What makes you think I didn't search this form (and audiforums, and the internet at large)? The only useful / related info to this that I could find based on the search terms I use was some guy who had a similar problem with a Jetta and it was related to a bad valve or something. QUOTE]
Becuase if you did, you would have found this by searching "transmission." Looks like the same issue to me:
https://www.audiworld.com/forums/sho...t=transmission
Might or might not be exactly what you were looking for, but I don't think you should take offense at my suggestion that you might find a lot of potentially helpful information already posted here... I didn't exactly call you a moron or anything...
