Serious Throttle Response Lag - 2010 A4 2.0t-Anyone Else?
#21
I find it exhausting to cruse above 110 mph for extended periods of time. Paying too much attention to the surrounding cars and after a couple hours I feel like I have run a marathon.
I have had enough close calls when I lived in Europe. Could have died a couple of times already.
100mph is no brainer and is fun, I agree. You can hardly feel it in this car.
I like the twisties better.
#22
One can get a kick out of the adrenaline, but it's a product of the risk that they are subjecting themselves to when driving fast.
The twisties and the kick one gets out of the acceleration are similar to the roller-coasters - it's much safer and fun at the same time.
#23
The issue with the fast driving on a highway is that you are not in control of the the behavior of the other drivers around you. I had a close call when an 18-wheeler cut me off while I was driving 100km/h faster, then a taxi cab did it and a mini van did it. In the last case I swerved into the breakdown lane on the right to avoid it, lost traction and spun 270 degrees across the other two lanes of busy traffic and miraculously ended up in one piece in the ditch on the left. I didn't want to drive for couple of days after that.
#24
I had a throttle response issue on my wife's A4. And didn't know it until I had a loaner. I know I just didn't like it. I called the dealership and they said they did a transmission software update. Well, it now drives like all the other loaners I've had. Why dont you try that?. I feel bad your having this problem. And I too know it was there. And I agree it's dangerous.
If they had said they could reset the memory and do a software update on the transmission, I'd let them do it...but now it's too late......
#25
Kinda OT but considering all the mods you talk about eventually adding to your A4, I would think that you would have bought an S4 and saved some money and time... Of course you will pay more at the pump but it's all about smiles per gallon not mpg.
I would get an ECU tune and light weight wheels before you spend $$$$ on mods that won't make any difference on the street.
Intercooler upgrade is a waste unless you track your car. If you are just running on the street or even dragstrip, you will have more than enough time between full throttle runs for the factory intercooler to mitigate heat buildup. Better talk to some folks with HFC's about efficiency codes getting thrown. Intake and exhaust will give you more noise. woohoo! A high flow exhaust does offer a few benefits if you can live with the extra noise on a daily basis. First, boost will rise as backpressure is reduced. Second, reducing backpressure will add longevity to the seals by pushing exhaust heat from the turbine housing faster.
Just my experience for the .02 its worth...
I had the APR tune last year, but it fried my ECU. Needless to say, the wife was pissed... so for now the mods are going to be hardware based. I know the IATs aren't huge from daily driving, but it'll be interesting to see what the Turbo outlet adapter and the lack of a sound box do to allow faster turbo spooling.
I understand with an HFC that the only 100% way to get rid of the CEL is to upgrade w/ APR Stage 1.5 or 2.
I'm following a thread on AZ where someone is using a newer spacer on the 2nd o2 spacer on the Cat. It could solve the CEL issue w/out an APR upgrade.
I'm still on the fence regarding which exhaust to go with... down to two choices.
I hear what yer saying, though. Wheels are on my wish list when I get more chump change. That's a whole can of worms I'm not ready to get into yet.
#26
The first two were in Europe, but not in Germany. The 270 spin as in the US. It's not about being disciplined. It's mostly about not seeing the speeding guy when changing lanes. At these speeds you look to the left to change the lane, blink, make a move, and car fills up your rear view mirror out of nowhere.
#28
ON topic - He's seeing a combination of things. An adaptive ECU and TCU, e-throttle, and intentional TCU programming. The turbo lag on the A4 really is pretty minimal, but the programmed TRANSMISSION lag is very real, annoying, and potentially dangerous. There is NO reason Audi needed to program in a 2-second gap that kicks in when you hit the gas after slowing down but not stopping. If someone coudl tune that out of the TCU they'd make a killing. I know I'd be first in line.
#29
#30
I need a quart of oil about 1,200 miles. A brilliant engineer (not Audi's) explained to me why turbos burn oil. He convinced me to to worry. I lease it anyway. Metro NY driving may increase oil consumption in my opinion. 30+ mph on the highway has been a reward.
