Standard Aux-in with iPod Adapter
Hi guys. I have a '10 Premium+ with the Audi iPod Interface which means I lose the aux-in in the center console. Is there a cable (OEM or 3rd party) that will allow me to go aux-in into the iPod Interface connector? The reason I want this is because there are times when I want to use the audio from 3rd party apps on the iPhone (e.g. Pandora). Thanks!
There's an Audi aux-in cable available that replaces the iPod cable - plugs into the same place as the iPod cable in the glove compartment.
There's also a Bluetooth adapter available (kind of pricey, IIRC) that will connect to the stereo bluetooth audi out on the iPhone.
- Dennis
- Dennis
Are 2009 & 2010 AMI cables the same with Navi?
This link shows it works with the 2009 model, for $18 + $5 S&H.
http://cgi.ebay.com/Audi-3-5mm-3-5-m...item5ad8e739db
Wow! Didn't see that one. This is the one I saw: http://cgi.ebay.com/ebaymotors/AUDI-...fAudioQ5fVideo
I also believe you can't stream Pandora from a AMI cable connected iphone, only able to control content off the iphone's harddrive.
Aux In MMI 3G
I ended up biting the bullet and buying both the Aux-In and USB cables from my local Audi dealer (~$110 for both cables). I typically use the Aux-In for daily use and the USB for long trips (power does go through the USB so you can use bus-powered USB hard drives). As previously noted, when using the Aux-In, all navigation must be done through your attached device.
Thanks! Insanely high price to pay for a cable, but as long as it works it's worth it to me. Question, on the MMI screen what is the source name listed that allows you to select the device connected via the aux cable?
