Stasis swaybar 22mm vs 28mm?
I was looking to order a swaybar from stasis... I came to an order page and noticed 2 sizes.
22mm
28mm
Is the 28mm simply "stiffer"? Is there any difference between the 2? They were the same price.
22mm
28mm
If you want slightly sportier handling and you don't already have the sports package or s-line package, I'd say get some coilovers or sprints + struts. It will improve the look of your car as well as the handling and should make a bigger impact than just getting sway bars.
I'm not sure if they have strut bars for the A4 B8, but those are typically cheap and an easy bolt on install.
Check with Stasis on this as the recommended bar for the A4 is now a 23mm one. The 28mm is still recommended for the S5, and I have no idea if they recommend the 22mm bar at all now.
When I spoke with them, they said that the A4 should take the 23mm bar (which was once expected to be 24mm) even with Sport suspension, S-Line or aftermarket springs. They said with coilovers a customer could go with either the 23mm or 28mm bar, as long as they realize that the larger bar is very stiff, and as Blake reported, could result in some three-wheeling.
I'm trying to organize a group buy for the 23mm bar. I'll post something on AudiWorld soon but there's a post on AudiZine in the A4 B8 forum as well. http://www.audizine.com/forum/showthread.php?t=303892
- Jason
- Jason
- Jason
- Jason
I'd be in for a group buy! (try and get just B8 sway bars! :P I would probably get the 28)
ernestolopez
A4 (B8 Platform) Discussion
01-08-2011 11:15 PM
Benlives
04-21-2010 03:01 PM
PILL PUSHER
07-20-2007 04:26 AM
S4Per
9
06-16-2003 03:01 PM
