Transmission problem
Hey
I have 2008 audi a4 b8 automatic, I have problem that when I put the gear on drive and accelerate the RPM will move but the speed will still 0 but after 2 seconds the car will start jumping for a second and then everything fine I can drive it and it will change gears very smooth . This problem happens only in the morning when the car is cold. I changed the gear oil and I took the car to audi but they said we don't know what's the problem
so please can anyone help me
Hey
I have 2008 audi a4 b8 automatic, I have problem that when I put the gear on drive and accelerate the RPM will move but the speed will still 0 but after 2 seyou eitheconds the car will start jumping for a second and then everything fine I can drive it and it will change gears very smooth . This problem happens only in the morning when the car is cold. I changed the gear oil and I took the car to audi but they said we don't know what's the problem
Sorry but if they said there is no problem with the transmission then did you ask them what the problem was. I would ask what the transmission pump and what the pressures were . If the transmission selector is placed in drive and when you step on the accelerator the car does not move either the selector didn't engage drive or the transmission is slipping. If this is a quattro then they need to check this on a AWD dyno stand . Also you didn't mention if there were any codes on the instrument cluster. I would assume that this will get worse .
Kojotous
02-09-2011 08:06 AM
