Troubleshooting MMI 3G
Could use some advice on troubleshooting a non-working MMI in a 2010 A4 2.0 M/T, Premium Plus trim with GPS navigation.
Main symptoms are the screen is off, won't turn on, the controls near the shifter don't light up, all MMI features are absent from the instrument cluster (media/voice command/etc).
- Fuses all look fine, swapped them around to confirm and nothing changed.
- CD drive makes noise when eject is pressed. Press top right + bottom left buttons around the selector wheel (supposed to be MMI reset) results in a slight click/pop through the speakers, seems like it's turning on/off.
- Reverse proximity sensors are still beeping as before - and it's using the sound system speakers if I'm not mistaken.
- I using a fiber optic bypass loop in place of the module in the left (driver) side of the trunk, didn't seem to do anything. I'm a little skeptical if optical connectors were adequate, can't think of a way to verify it.
Scanned the car with OBD11, the three MMI-related modules (19 CAN Gateway, 56 Radio, 5F Multimedia) all seem to be alive and not reporting any trouble codes:
The rear view camera started being flakey - not turning on when put in reverse - a few months before the MMI went dead. Currently the camera module is detecting when the reverse gear is engaged/off (on live data screen).
Also found an old scan in my email from 3 years ago when the MMI was fine, there were three subsystems showing for that module which are gone now:
01 Engine
System description: 2.0l R4/4V TF
Software number: 8K2907115AL
Software version: 0001
Hardware number: 8K2907115D
Hardware version: H16
ODX name: EV_ECM20TFS0118K2907115AL
ODX version: 001001
Long coding: 0104010A180F0160
Trouble codes:
No trouble codes found
03 Brakes
System description: ESP8 quattro
Software number: 8K0907379CA
Software version: 0030
Hardware number: 8K0907379CA
Hardware version: H04
Serial number: --------------
Long coding: 070D18
Trouble codes:
02214 - Tire pressure warning
static
Priority: 4
Frequency counter: 254
Driving cycle: 73
Mileage: 258168 km
Date: 2023-03-24 18:53:47
05 Keyless System
System description: BCM2 1.1
Software number: 8K0907064DG
Software version: 0327
Hardware number: 8K0907064DG
Hardware version: H02
Long coding: 0B0100
Subsystems:
System description: FBSAUDIB8 IDG
Software number: 8K0959754B
Software version: 0083
Hardware version: H71
Serial number: 0815000086179012
System description: J764 ELV MLB
Software number: 8K0905852D
Software version: 0042
Hardware version: H37
Serial number: 0210000022621008
Trouble codes:
08 Air Conditioning
System description: KLIMA 3 ZONEN
Software number: 8T1820043AQ
Software version: 0171
Hardware number: 8T1820043AQ
Hardware version: H08
Serial number: 01050320100199
Long coding: 64102000
Trouble codes:
09 Central Electrics
System description: BCM1 1.0
Software number: 8K0907063P
Software version: 0380
Hardware number: 8K0907063P
Hardware version: H25
Serial number: 00000000484498
Long coding: 26001091063CAF010000080300003D0D0F1C12080201016100 0000
Subsystems:
System description: WWS 110310
Software number: 8K1955119A
Software version: 0070
Hardware version: H06
Serial number: SWF10030116559
Long coding: 00FD11
System description: RLS
Software number: 8K0955559
Software version: 0003
Serial number: 10814390
Long coding: 025028
System description: E1 - LDS
Software number: 8K0941531AL
Software version: 0090
Serial number: 00000000002702101001
System description: HOMELINK
Software number: 8K0907410C
Software version: 0010
Hardware version: H01
Trouble codes:
10 Parking Assistance
System description: PARKHILFE 4K
Software number: 8K0919475Q
Hardware number: 8K0919475
Serial number: 51241006901228
Long coding: 200003
Trouble codes:
15 Airbag
System description: AirbagVW-AU10
Software number: 8K0959655K
Software version: 0610
Hardware number: 8K0959655K
Hardware version: H41
Serial number: 003GLD0D2APH
ODX name: EV_AirbaECUVWAUDI010
ODX version: 003010
Long coding: 303837354230303030304A55304C384B3053
Subsystems:
System description: BF-Gewichtss.
Software number: 8K0959339B
Serial number: 5810000R10000067SM
Trouble codes:
16 Steering Column
System description: Lenks.Modul
Software number: 8K0953568F
Software version: 0014
Hardware number: 8K0953568F
Serial number: 90304JCA000C9
Long coding: 000016
Subsystems:
System description: E221 - MFL
Trouble codes:
17 Dashboard
System description: KOMBIINSTR.
Software number: 8K0920980M
Software version: 0255
Hardware number: 8K0920980M
Hardware version: H20
Serial number: CIX16N43A
Long coding: 8B1509000300D705020000
Trouble codes:
19 Gateway
System description: GW-BEM 4CAN-M
Software number: 8T0907468AD
Software version: 0116
Hardware number: 8T0907468K
Hardware version: H09
Serial number: 5500E102270160
Long coding: 00C303
Subsystems:
System description: J367-BDM
Software number: 8K0915181E
Software version: 0170
Hardware version: H07
Serial number: 1000D1A4050310
Trouble codes:
03041 - Energy management active
Intermittent
Priority: 7
Frequency counter: 22
Driving cycle: 87
Mileage: 262589 km
Date: 2023-07-16 07:22:00
42 Driver Door
System description: TSG FA
Software number: 8K0959793H
Software version: 0306
Hardware number: 8K0959793D
Hardware version: H11
Serial number: 0000010141867
Long coding: 011C03204000410001
Trouble codes:
46 Comfort System
Serial number: 0127996844
Long coding: 0106063A007A444400B0013200000000
Subsystems:
System description: GTO BF
Software number: 8K0959719
Software version: 0050
Serial number: 00000000000000233108
System description: LIN BACKUP HO
Software number: 1K0951605C
Software version: 1501
Hardware version: H05
System description: J245 PS037
Software number: 8K0959591A
Software version: 0041
Trouble codes:
52 Passenger Door
System description: TSG BF
Software number: 8K0959792H
Hardware number: 8K0959792D
Serial number: 0000010235836
Trouble codes:
53 Parking Brake
System description: EPB Audi B8
Software number: 8K0907801H
Software version: 0100
Hardware number: 8K0907801H
Serial number: 00000000583647
Trouble codes:
55 Headlight Regulation
System description: Dynamische LWR H01
Software number: 8K5907357
Coding: 0000004
Trouble codes:
56 Radio
System description: Radio U SIRIU
Software number: 4F0035082A
Software version: 0021
Hardware number: 4F0035082
Hardware version: H45
Serial number: 335CY0A7558271
Long coding: 020000020100000001
Trouble codes:
5F Multimedia
System description: H-BN-NA
Software number: 8T1035664B
Hardware number: 8T1035664B
Hardware version: H47
Serial number: 490CV0A7553154
Long coding: 010200000006A1EF01000B0E000000030000
Trouble codes:
62 Rear Left Door
System description: TSG HL
Software number: 8K0959795C
Hardware number: 8K0959795C
Hardware version: H10
Serial number: 0000103090638
Long coding: 010C03204000210001
Trouble codes:
6C Rear View Camera
System description: J772__Rearview
Software number: 8T0907441C
Software version: 0040
Hardware number: 4L0907441B
Serial number: 525PA8-J029249
Coding: 1000006
Trouble codes:
02203 - Audio-/video input 1 Open circuit
Intermittent
Priority: 4
Frequency counter: 102
Driving cycle: 111
Mileage: 253948 km
Date: 2023-01-05 16:48:17
02203 - Audio-/video input 1 Implausible signal
Intermittent
Priority: 3
Driving cycle: 98
Mileage: 264397 km
Date: 2023-09-16 13:07:40
72 Rear Right Door
System description: TSG HR
Serial number: 0000103089990
Trouble codes:
01 Engine
ODX version: 001001
Trouble codes:
03 Brakes
Long coding: 070D18
Trouble codes:
static
Priority: 4
Driving cycle: 73
Mileage: 258168 km
05 Keyless System
Long coding: 0B0100
Subsystems:
Trouble codes:
08 Air Conditioning
Trouble codes:
Subsystems:
Long coding: 00FD11
Long coding: 025028
Trouble codes:
Long coding: 200003
Trouble codes:
15 Airbag
ODX version: 003010
Subsystems:
Trouble codes:
16 Steering Column
Long coding: 000016
Subsystems:
Trouble codes:
17 Dashboard
Trouble codes:
19 Gateway
Long coding: 00C303
Subsystems:
Trouble codes:
Intermittent
Priority: 7
Driving cycle: 87
Mileage: 262589 km
42 Driver Door
Trouble codes:
46 Comfort System
Subsystems:
Trouble codes:
52 Passenger Door
Trouble codes:
53 Parking Brake
Trouble codes:
Coding: 0000004
Trouble codes:
56 Radio
Trouble codes:
5F Multimedia
Trouble codes:
62 Rear Left Door
Trouble codes:
6C Rear View Camera
Coding: 1000006
Trouble codes:
Intermittent
Priority: 4
Driving cycle: 111
Mileage: 253948 km
Intermittent
Priority: 3
Driving cycle: 98
Mileage: 264397 km
72 Rear Right Door
Trouble codes:
5F Information Control Unit 1
Subsystems:
System description: NAR 2009/2010
Software number: 8R0060884F
Software version: 5304
System description: DU7 High
Software number: 4F0919604
Hardware version: H43
Serial number: 9356CQ0A1213962
System description: E0380 Bedient
Software number: 8T0919609F
Serial number: 00000000486241
System description: CD-Database
Software number: 8R0906961A
Software version: 1293
Trouble codes:
Subsystems:
Trouble codes:
@sm87 -- Pro tip: bracket your OBDeleven log text in a CODE block to preserve white spacing/indents in the text.
Looks like NAR MMI3G High with the original production software and nav database released in 2009 from your older scan log. It is odd/strange to me that the control panel -E380- responds to the three-button restart but is not reported in the diagnostic scan. Also that the nav & Gracenote databases are not reported. That suggests to me that the J794 main unit is not starting fully -- the main unit powers both the display & control panel. BTW, the module in the rear is the Radio (Address 56 in your scan).
I think if I were in this position, I would start by swapping the main unit with a spare and rescanning; the salvage market for old MMI3G main units is decent in the US so they can be found for fair prices -- for example: https://www.ebay.com/itm/386220714094 or https://www.ebay.com/itm/375085024214
You might also look for a male MOST bypass loop to isolate the main unit from the optical loop. If it's working properly, it will still start. Note also that a failed HDD will not generally cause the main unit to stop working, since the base operating system & MMI software is all stored in flash memory. --g
From what I gather there aren't any aftermarket replacements for the main MMI 3G unit, the kits I managed to find are all basically an android tablet bolted onto the dash and spliced into the wiring harnesses but all the "car" functionality (settings, TPMS reset, etc) is still handled through the stock MMI system - so seems I'll need to get it sorted out either way.
Main headache for the moment is I have no way to reset TPMS w/o the MMI screen, clearing the brake module faults doesn't work it comes right back, it HAS to be possible via coding but seems no one bothered to figure out the details (why would you when it's so simple via MMI).
Component protection will just disable some manner of functionality, the unit will fundamentally be operational. Plus you'll have an actual DTC for component protection active.
There's no reason for any third-party to produce an aftermarket J794. The only such thing is the Alpine head unit, which Alpine doesn't sell in the NAR market. None of the Android stuff replaces the J794. They insert themselves between the J794 and the display.
The backup camera issue is not related to the MMI system, except at the point where the video cable from the backup camera connects to the J794. 02203 is the connection to the camera unit itself. 02283 would be the connection to the J794. If you look at the camera control module, you'll see there are two FAKRA connections, gray to the camera and green to the front end system (J794 in your case).
The park distance sensors are not related to any other system. They have their own buzzer speaker mounted on the right rear seat belt shoulder mount. If you had front and rear sensors, they can be visualized in the MMI system with the "OPS" system.
Looking at parts and there are 4 variants of the main MMI unit:
8T1035664A - up to 10/2009
8T1035664B - from 11/2009
8T1035664C - from 11/2009
8T1035664D - to 10/2013
Seems like either of B, C or D should be OK as replacements?
Came across this thread, going to try poking through UART when I pull it out. I hadn't messed with firmware or upgrades at any point in the past so not too much hope of simply reflashing it.
https://www.audiworld.com/forums/q5-.../#post24675090
A was 1H MY10, B was 2H MY10, C was MY11, D was MY12. The revs were always updating to reflect the updated nav data factory load. I don't know if the units have any physical difference otherwise. MY11 added HD Radio, but that was likely only a change in the radio unit (change from 4F... to 4G... units). It would be curious if you could go with a B8.5 MMI 3G+ unit and pick up the integrated Bluetooth audio streaming support, if you're replacing the entire unit, if that's a function that would be interesting.
@sm87 -- SMac is correct re the part number versions: inspection of the manufacturing labels on main units shows also that updated system software is installed on these at production. Later doesn't mean better here, since we can apply these software and nav database updates, as needed. I'd go with low cost to test, then update as necessary.
Re swapping with a later MMI3GP main unit (e.g., 8R1035746), while lots of these are around for fair prices, the MMI3GP control head is different & would likely need to be replaced, too. Back when we had 3G mobile data, MMI3G High to Plus conversions were a thing (so, it can be done). --g
Update:
Just got another MMI unit off ebay (8T1035664C to be exact), popped it in, things came back to life immediately, component protection activated as predicted. Interestingly enough the reverse camera works too, I thought it went bad since it stopped working before the old MMI.
I heard the radio for a second or two the first time turning it on but now there's no sound (component protection I assume). I was able to verify sound is working by going into reverse-gear volume fade settings, while on the adjusting screen the radio plays as normal.
Navigation system seems to work, reports 6-8 satellites but map is not centering on my location but it does show the right direction where car is pointing, also guessing this is CP.
It did let me reset the TPMS warning (finally) and adjust the time - so looks like all the "boring" stuff isn't affected by component protection. Going to call a couple of shops tomorrow to see if they can reset it for me before going to the dealer.
Here's the scan with the new MMI module:
Couldn't make time to mess with the old MMI to try and reflash it or diagnose further via serial console, so nothing interesting to report there.
Code:
--------------------------------------------------------------- 56 Radio System description: Radio U SIRIU Software number: 4F0035082A Software version: 0021 Hardware number: 4F0035082 Hardware version: H45 Serial number: 335CY0A7558271 Long coding: 020000020100000001 Trouble codes: 02984 - Connection between impedance converter 2 and window antenna Open circuit static Priority: 5 Frequency counter: 21 Driving cycle: 186 Mileage: 233993 km Date: 2021-04-28 20:06:17 00417 - Left front DSP mid-bass speaker Open circuit static Priority: 5 Frequency counter: 1 Driving cycle: 172 Mileage: 233993 km Date: 2021-04-28 20:06:08 00418 - Right front DSP mid-bass speaker Open circuit static Priority: 5 Frequency counter: 20 Driving cycle: 186 02095 - Component protection active Intermittent Priority: 4 Frequency counter: 1 Driving cycle: 119 --------------------------------------------------------------- 5F Multimedia System description: H-BN-NA Software number: 8T1035664C Software version: 0116 Hardware number: 8T1035664B Hardware version: H51 Serial number: 490CS0B7611164 Long coding: 010200060005A1EF41000B0E000000030000 Subsystems: System description: NAR 2011 Software number: 8R0060884AL Software version: 0506 System description: DU7 High Software number: 4F0919604 Software version: 0306 Hardware version: H43 Serial number: 9356CQ0A1213962 System description: E0380 Bedient Software number: 8T0919609F Software version: 0100 Hardware version: H08 Serial number: 00000000486241 System description: CD-Database Software number: 8R0060961 Software version: 1886 Trouble codes: 03276 - Checking software version management static Priority: 6 Frequency counter: 1 Driving cycle: 79 Mileage: 265334 km Date: 2023-12-12 20:53:10 00658 - Operating unit No signal/communication Intermittent Priority: 5 Frequency counter: 1 Driving cycle: 119 03157 - Function restriction due to communication interruption static Priority: 6 Frequency counter: 1 Driving cycle: 79 Mileage: 265334 km Date: 2023-12-12 20:53:46 02095 - Component protection active static Priority: 4 Frequency counter: 1 Driving cycle: 79 Mileage: 265334 km Date: 2023-12-12 20:53:30 02095 - Component protection active Implausible signal Intermittent Priority: 4 Frequency counter: 1 Driving cycle: 119 Mileage: 265334 km Date: 2023-12-12 20:53:30 --------------------------------------------------------------- 62 Rear Left Door System description: TSG HL Software number: 8K0959795C Software version: 0306 Hardware number: 8K0959795C Hardware version: H10 Serial number: 0000103090638 Long coding: 010C03204000210001 Trouble codes: No trouble codes found --------------------------------------------------------------- 6C Rear View Camera System description: J772__Rearview Software number: 8T0907441C Software version: 0040 Hardware number: 4L0907441B Serial number: 525PA8-J029249 Coding: 1000006 Trouble codes: 02203 - Audio-/video input 1 Open circuit Intermittent Priority: 4 Frequency counter: 102 Driving cycle: 111 Mileage: 253948 km Date: 2023-01-05 16:48:17 02203 - Audio-/video input 1 Implausible signal Intermittent Priority: 3 Frequency counter: 1 Driving cycle: 98 Mileage: 264397 km Date: 2023-09-16 13:07:40
@sm87 -- That's an encouraging result. Current software version for your main unit is HNav_US_K0133_3_D1; I have it here: https://www.vwvortex.com/threads/aud...tware.9471271/
Also, I have a more recent nav database here: https://www.vwvortex.com/threads/8r0...post-115272158
I helped a fellow in CA recently with some questions he had about his MMI3G High system -- he has access to the latest MMI3G nav database update (2021/2022), released in late 2020. Maybe he'll find time to make it available to the AW MMI3G community.
The DTCs in the RVC controller are likely due to previous video cable disconnects; based on the freeze frame dates, they can be cleared/erased. --g
@drgertol Thanks for the links, got my hands on some (working) SD cards and installed the updates yesterday. All went smoothly but took quite some time, first one about an hour or and the nav data probably another 2 hours.
With the new software GPS now works fully for the first couple of minutes after starting the car and then only shows "Navigation data is blocked". Is it even possible for independent shops to (legally) reset component protection or an I wasting my time? I found some threads about a guy in Poland being able to do it remotely, wonder if it's a dealership tech running a side hustle, the two 'German car specialists' around here both said only Audi service department will be able to do that.
By the way with an SD card >32GB Windows only let you format it as exFAT (which MMI doesn't seem to like) instead of FAT32, workaround is to just create a 32GB partition (leaving the rest of the space unused) and format that as FAT32 for the update. In theory FAT32 should support larger volume sizes so this seems like a Windows-specific thing.
