Troubleshooting MMI 3G
#11
@sm87 -- Re "navigation data is blocked", I have a SD patch script for that here: https://github.com/DrGER2/MMI3G-Navdb-Unblocker
This isn't a function of CP, rather, the method Harman-Becker uses to "activate" a navigation database. Not my method, just my implementation of the method.
The GNU Partition Editor (gparted) will format a 64 GB SD card as FAT32 successfully -- I used it regularly on our Linux desktop(s). Yeah, it's Windows being, well, Windows. --g
#12
@drgertol I'm curious, you seem to be pretty deep into this, do they use cryptographic signatures from VAG (requiring ODIS to phone home) to enforce the map activation and component protection schemes or is it mostly security-through-obscurity that no one was bothered enough to reverse engineer so far?
#13
@sm87 -- Nav database activation and CP are completely different processes -- CP lives in the main unit EEPROM (my understanding), while navdb "activation" lives in the FSC file pointed to by the navdb release PKG file, which is part of the navdb installed on the HDD. The FSC file is stored elsewhere -- in one of the flash memory file systems that is persistent across system software updates and appears to be created by a Red Engineering Menu process initiated by ODIS.
I'd say, run my unblocker script, then clear the other DTCs left in Address 5F/J794. I don't know that ODIS can tease out that an installed navdb is activated normally or that the normal H-B navdb activation process is disabled -- they both look the same without inspecting the running QNX system. Not much is known about the structure of Harman-Becker VAG FSC files of this generation, or at least that I've been able to tease out. --g
#14
@drgertol Alright, so the nav script worked exactly as advertised, no errors in the log file, navigation system is now fully functional even with component protection active! Gotta say, I'm a little shocked by how the MMI just runs any random run.sh as soon as an SD card was plugged in, with root none the less, and OS partitions are mounted read-write (thought maybe I'd have some integrity checks), but I digress.
Did some digging on FSC and found your other thread on the topic, are you looking for more *.fsc specimens?
After clearing the error codes this is what I'm left with:
It seems both driver and passenger front door speakers are indeed not producing any sound:
00417 - Left front DSP mid-bass speaker Open circuit
00418 - Right front DSP mid-bass speaker Open circuit
From what I've read it seems like a known problem with contacts coming loose in those speakers, yay messing with interior panel clips...
As for the window antenna code (02984 code), that one has been showing up in the old scans too (+3 years ago) but I don't remember ever having issues with FM radio (including now).
Still trying to find someone to take care of component protection. I'm mulling just getting a VAS 5054/6154 clone off aliexpress for $100 and paying another 2$5 for a 1-day ODIS login (although not sure how legit these are?), cost would end up less than an hour of shop time. Or maybe just find someone doing ODIS remotely who know what the hell they're doing with it, I hear it's a peculiar piece of software.
Code:
... --------------------------------------------------------------- 56 Radio System description: Radio U SIRIU Software number: 4F0035082A Software version: 0021 Hardware number: 4F0035082 Hardware version: H45 Serial number: 335CY0A7558271 Long coding: 020000020100000001 Trouble codes: 02984 - Connection between impedance converter 2 and window antenna Open circuit static Priority: 5 Frequency counter: 1 Driving cycle: 84 Mileage: 265836 km Date: 2023-12-17 15:20:42 00417 - Left front DSP mid-bass speaker Open circuit static Priority: 5 Frequency counter: 1 Driving cycle: 84 Mileage: 265836 km Date: 2023-12-17 15:20:33 00418 - Right front DSP mid-bass speaker Open circuit static Priority: 5 Frequency counter: 1 Driving cycle: 84 Mileage: 265836 km Date: 2023-12-17 15:20:33 --------------------------------------------------------------- 5F Multimedia System description: H-BN-NA Software number: 8T1035664F Software version: 0189 Hardware number: 8T1035664B Hardware version: H51 Serial number: 490CS0B7611164 Long coding: 010200060005A1EF41000B0E000000030000 Subsystems: System description: NAR 2017/2018 Software number: 8R0060884EN Software version: 1602 System description: DU7 High Software number: 4F0919604 Software version: 0306 Hardware version: H43 Serial number: 9356CQ0A1213962 System description: E0380 Bedient Software number: 8T0919609F Software version: 0100 Hardware version: H08 Serial number: 00000000486241 System description: CD-Database Software number: 8R0060961 Software version: 1886 Trouble codes: 03276 - Checking software version management static Priority: 6 Frequency counter: 1 Driving cycle: 84 Mileage: 265836 km Date: 2023-12-17 15:05:37 03157 - Function restriction due to communication interruption static Priority: 6 Frequency counter: 1 Driving cycle: 84 Mileage: 265836 km Date: 2023-12-17 15:05:39 02095 - Component protection active static Priority: 4 Frequency counter: 1 Driving cycle: 84 Mileage: 265836 km Date: 2023-12-17 15:05:36 --------------------------------------------------------------- 62 Rear Left Door System description: TSG HL Software number: 8K0959795C Software version: 0306 Hardware number: 8K0959795C Hardware version: H10 Serial number: 0000103090638 Long coding: 010C03204000210001 Trouble codes: No trouble codes found --------------------------------------------------------------- 6C Rear View Camera System description: J772__Rearview Software number: 8T0907441C Software version: 0040 Hardware number: 4L0907441B Serial number: 525PA8-J029249 Coding: 1000006 Trouble codes: No trouble codes found --------------------------------------------------------------- 72 Rear Right Door System description: TSG HR Software number: 8K0959795C Software version: 0306 Hardware number: 8K0959795C Hardware version: H10 Serial number: 0000103089990 Long coding: 010C03204000210001 Trouble codes: No trouble codes found ...
#15
@sm87 -- DTC 03276 is cleared by entering a checksum value in Adaptation Channel 15 of Address 5F (see page 39 of my update document: https://drive.google.com/file/d/1TP6...K3dYx6eSk/view). I don't recognized DTC 03157 being related to the nav database.
This generation of Harman-Becker systems don't run just any "random" shell script -- Process proc_scriptlauncher acts on (lightly) encrypted file copie_scr.sh when it is found on an SD card at an insertion event. We use a standardized copie_scr.sh that sets up some environment variables, then launches/executes plain-text "run.sh" from the SD card root directory (described here: https://github.com/DrGER2/copie_src.sh).
Re your production FSC file, if you have a copy of it, I could use it in my collection for inspection. Cheers --g
#16
Attached zip has the .fsc files pulled from the MMI, in the 00040003.fsc file I see VIN of the donor car embedded in it (matches the ebay listing), if that helps.
drgertol (12-19-2023)
#17
@sm87 -- Thanks for the ZIP -- I'll poke at that later, as time permits. The flash memory & SD card filesystems are all (mostly?) mounted read-only initially, hence our need to update the mount when our "run.sh" script is run with "mount -uw /path/to/dir". If you haven't examined the contents of your MMI3G/HNav system yet, take a look at my MMI3G Info Report script: https://github.com/DrGER2/MMI3G-Info
One bit that eludes me so far is finding a way to read the contents of the main unit EEPROM from the shell. We know the Java user interface (the UI, including the Red & Green Engineering Menus run in a Java VM) can read the EEPROM -- alas, H-B didn't give us a separate QNX binary to do that, too. --g
#18
On a different note, I need to replace both front door speakers (wires going to the coil rotted form moisture, seems to be a common failure). I'm trying really really hard to go down another rabbit hole with this one , so in light of that I want to stick to stock wiring and amp here. I found the kit captain_video here sells to put Dayton RS75 tweeters in the dash (seems like great value for the $) so I figured those should pair well with door woofers from the same RS series ...but those only come in 6", 7" and 8" - because of course - so they won't fit the 6.5" speaker adapters available for this car. Any suggestions for another 6.5" midrange woofer to complement the RS75s? On all the other threads people are getting more elaborate with the upgrades ..must ..resist.
@SMac770 I came across this diagram you posted https://www.audiworld.com/forums/a4-.../#post25812870
If the door woofer and tweeter are wired in parallel, and I'm seeing an open circuit at the amp/radio harness, does this mean the tweeter is also kill? If I short out the door speaker harness with a jumper wire I see continuity again,
#19
Yeah, all the tweeter branches have in-line caps for a first order low cut filter for the tweeter. Whether that's for bass blocking, turn on thump protection, or both, can't guarantee the why; just that the function is there.
I believe the cap is at the tweeter itself, so if you can lift those up and out of the dash corners, you can get to the wiring plug and then test the wiring per normal.
#20
@sm87 -- All of the UI Java code lives in a proprietary IBM JXE jar in /mnt/ifs-root/lsd/lsd.jxe. I have ZIP archives of some ifs-root.ifs & efs-system.efs image files over on AZ in case you're really interested in poking at any of this: https://www.audizine.com/forum/showt...1#post14904929 --g
