Troubleshooting MMI 3G
#21
https://stackoverflow.com/questions/...r-to-intel-jxe
I wonder if that jxe converts to a jar that JD Gui can convert back to any manner of understandable Java.
https://stackoverflow.com/questions/...va-source-code
As the discussion in the second link points out, JD-GUI can't always produce useful decompile. Ran into this when I wanted to fix a "shareware" toolset that the origins of were long gone. It chewed up a CPU all the time after an event. Luckily, the defect was in one of the .java that had fully decompiled, so I was able to mod it, recompile it, and "fix the issue" with the .jar product. But a lot of the files had long strings of gibberish.
#22
Results with JD were so-so, many "// INTERNAL ERROR //" and methods left as JVM byte code.
Going to try with fernflower tomorrow, looks much more promising:
https://www.decompiler.com/jar/187db...eeringApp.java
https://www.decompiler.com/jar/d9dd7...onnection.java
Definitely some interesting looking stuff there
#23
I've checked all the usual suspects (8-pin SMDs packages) but they all turned out to be something else, here's both sides of the motherboard:
https://1drv.ms/i/s!Ao-UlylWvwgziapx...A5fhg?e=V7nL13
https://1drv.ms/i/s!Ao-UlylWvwgziapy...r_Osg?e=DFRx3N
(forum won't accept the upload, too big maybe)
Notes on components I've checked so far, there's one that I couldn't match to a datasheet (4453) but there were a couple of those and surroundings didn't seem typical for an EEPROM:
Top side with HDD (marked BS in corner):
AD8052 / ARZ / #002
Rail-to-Rail Amplifier
https://www.analog.com/media/en/tech..._8052_8054.pdf
TDA8579 / 61 13 / n6003 / NXP
Dual common-mode rejection differential line receiver
https://www.nxp.com/docs/en/data-sheet/TDA8579T.pdf
L75A / 33 07 / 949
Digital temperature sensor and thermal watchdog
https://www.nxp.com/docs/en/data-sheet/LM75A.pdf
A1770 / M / 002
MOSFET
https://mm.digikey.com/Volume0/opasd...770_4-1-10.pdf
Other side:
431AIY / E9936
Programmable Voltage Reference
https://pdf1.alldatasheet.com/datash...CS/431AIY.html
33202 / PCSE
Low Voltage, Rail-to-Rail Operational Amplifier
https://pdf1.alldatasheet.com/datash...I/MC33202.html
CY2305C / SXA-1H / 9496490
Zero Delay Clock Buffer
https://www.infineon.com/cms/en/prod...y2305csxa-1h/#
https://www.infineon.com/dgdl/Infine...7d0ec649ec3c6d
4453
SS (logo) AD (hollow triangle)
.WO1B
989 / ATA6662 / 68506A-2
LIN Transceiver
https://ww1.microchip.com/downloads/..._Datasheet.pdf
AD8052 / ARZ / #002
L75A / 33 07 / 949
A1770 / M / 002
MOSFET
Other side:
431AIY / E9936
33202 / PCSE
4453
.WO1B
LIN Transceiver
#25
Cannot read the chip numbers in your two board pics as the resolution is too low.
If your CP data is in a separate SMD eeprom then the chip is most likely located near a large QFP processor.
Yes the newer modules have CP content moved inside large multifunction processors. It is possible yours is one of the early ones to do so.
#26
@sm87 -- Did you see this reference: https://www.audienthusiasts.com/Info...nt_EEPROM.html ?
8-pin device "Q3 A / AT64A" appears to be in the lower right of the underside of the system board in this image: blob:https://photos.onedrive.com/29b026fa...b-26c3678f3270
Just to the right of the "ISSI" chip. --g
#28
Dang that chip is tiny, roughly zero chance I'll manage to solder it back on successfully.
On a good note, I found more interesting information in the java source! There's a class called CarCodingEEPROM and true to the name has methods to read a bunch of version/model data using an abstraction called StorageManager.
Long story short - and many many abstraction layers apart - it's simply reading/writing to /dev/dsi/data, literally boils down to:
Code:
this.out = new FileOutputStream("/dev/dsi/data"); this.in = new FileInputStream("/dev/dsi/data"); DSIStream request = new DSIStream(); request.init(componentType: 12, instanceNumber: 0, processType: 3, subType: 1000, handle); // subType is the "command" indicating read/write and data type, rest are constants. request.writeTo(this.out); DSIStream response = new DSIStream(); response.readMessage(this.in);
The request and response messages format seems very straight forward, header + payload type deal, the DSIStream class handles all of that business. And I don't see any FileOutputStream.getChannel().lock() calls so file might not even be blocked (so perhaps no need to kill or preempt the MMI process). I haven't tested any of this yet, but if this all holds messing with the MMI EEPROM could be as simple as:
Code:
dd if=/mnt/sdcard/dsi-request.bin of=/dev/dsi/data dd if=/dev/dsi/data of=/mnt/sdcard/dsi-response.bin
#29
@sm87 -- Oh, well done ! Merry Christmas ! I see that we have two named special files /dev/dsi/data and /dev/dsi/debug at run-time.
Except that we don't have a native QNX binary for dd, but I can give this a quick look tomorrow:
and see what gets captured to the SD card.
BTW, some docs on QNX 6.3.0 here: https://openqnx.com/static/neutrino/bookset.html --g
Code:
cat /dev/dsi/data > ${SDVAR}/dsi-$(getTime).dat
#30
Would be awesome to figure out how to copy CP data and reflash content into a replacement module!
Takes about 10 minutes to move the chip. Works well for instances where a module is dead.
It’s not too bad if you can find someone who works on stuff like this.
