A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Using 89 or 91 octane in an Audi A4 2009
Old 06-19-2012, 06:35 AM
adiraval's Avatar
Default Using 89 or 91 octane in an Audi A4 2009
Dear all, would it be okay to use 89 octane or 91 octane for a 2009 Audi A4 2.0T Quatrro? Many thanks, Adi,
Old 06-19-2012, 07:35 AM
Macallan21's Avatar
I wouldn't use 89. It's basically the regular fuel with a shot of octane boost.
91-93 is all Premium and fine.
Old 06-19-2012, 08:08 AM
snagitseven's Avatar
While they recommend premium fuel, Audi's modern engine management systems allow for any grade down to regular. However, be aware that your car's performance will be throttled back. For a $40K+ car, the modest savings of a slightly less expensive fuel grade is kind of like buying a $3000 HDTV and using a VHS recorder for your video source. Yeah, it will work but will you get the most performance out of the investment you made?
Old 06-19-2012, 08:34 AM
Macallan21's Avatar
Oh, don't do that again. Yes, the car is built to run on 87. It has to be, because of NHTSA. And it can do it.
We ran 91-93 on a Lexus RX350 2007 model for 3 years. Everything worked fine. Ran 87 on it for 2 years, and had 2 O2 sensors, the one that sees the fuel (up top I think) die, a year apart. Switched back to 91-93, for a year now, and no problems. At least at Lexus, that is a $600 repair.
While the car CAN do it, you're running it off spec, and just waiting for the ECU to remap to a different firing sequence and hoping everything mechanical works the same.
Old 06-19-2012, 08:35 AM
stan211's Avatar
Its never okay to go less than Premium in a Turbo Car. Yes, the engine management will handle the fuel okay, but really whats the point of buying an Audi then? Might as well get a mainstream sedan and poor 87 into it.
Old 06-19-2012, 09:03 AM
Macallan21's Avatar
I thought the Dodge SRT-4 had a turbo and ran on 87. Mind you, you don't see a lot of OLD SRT-4's still running, but I'm just saying, that a turbo doesn't dictate 91-93.
Old 06-19-2012, 09:04 AM
audiintheblood's Avatar
go with the 91 octane - better safe than sorry!
Old 06-19-2012, 09:09 AM
dscline's Avatar
So the moral is: Lexus O2 sensor life span is about 5-6 years. Fairly typical for any car.
Old 06-19-2012, 09:17 AM
OriginalSHARPY's Avatar
I have a semi-related question. Is it bad for the engine or vehicle in general if you go back and forth between 91 and 94? I plan on using 94 off the start, but sometimes the prices are just to ridiculous and I may drop to 91 for a few fill ups. Is it a better idea to just stick to one? or as long as you don't drop below 91, you're okay?
Thanks
Old 06-19-2012, 10:21 AM
Macallan21's Avatar
No. Please re-read what I wrote.
1st sensor went bad at Year 4. Same sensor (which is only 1 year old) went back at Year 5.
Originalsharpy, anything about 91 octane will be fine. When you open the gas cap cover, you'll see a sticker that explains the fuel requirement inside there. Where are you from? I haven't seen 94 octane in the Midwest.
Quick Reply: Using 89 or 91 octane in an Audi A4 2009
