VAG COM is awesome!....Mods on my car
#11
#13
I have done these same mods and also display the gear in use (both in drive and sport mode), disabled seat belt chime (though I always wear them) and have made the MMI hidden menu accessible (allowing the state of battery charge to be displayed in the MMI).
#16
There is a FMVSS that must be followed here in the US. Not sure on the Audi, but there is a specific distance from center of turn signal bulb to a specific brightness of headlamp bulb or in this case, LED DRL. It is possible that the distance is too close on the Lamp module to meet the US FMVSS.
#17
Today, thanks to a friend.He was able to change the following on the car.
1) Needle sweep @ start up.
2)Turn signal will be on when making turn,and the leds will remain on.No cancellation of leds while turn signal ON.
3)Open and close windows with remote key.
4)My favorite... oil temperature displayed, along with lap time/stop watch.
Highly recommend the mods.VAG COM is a good investment.
idk its weird because i can close the window but cant open them.
any info on this??
#18
Once you enable the remote to open/close your windows via VCDS you need to go into your MMI and look for a new setting and enable it there as well.
#19
#20
I was wondering anyone has done the front and rear foglight with high beam mod.
I went it to [09 – Cent. Elect.] [Coding - 07] -> [Long Coding Helper] ->
Byte 4 Bit 1 - Change 1 to 0 most have the check boxes for the code and the fogs dont have that option.
I tried changing the code manually in the binary but it returns with code not accepted. I'm new to Vag Com coding and understand what byte/bit needs changed but dont know if I'm missing a step.
any pointers?
Thanks
any pointers?
Thanks
