voltage difference from battery to posts under hood?
hi all, I've been chasing a battery discharge issue for a long time... In winter it'll lose charge overnight
Should there be a voltage delta between posts and battery itself?
Battery out i measured 12.14 (battery tested at 900CCA, so I'm told it was ok)
Put it in the car and measured 11.93 under the hood
Could there be a ground issue on main battery feed?
Alternator is a few years old, and pulled every fuse and ruled out parasitic draw
Voltage regulator maybe? It's a 2009 avant
Also, running it measured 12.96 under the hood. Positive post and negative post, as well as negative to alternator, both the same
Once I jump it, runs with no issues until it sits again and loses charge...
un your battery has a dead cell and thats the parasitic draw if its fully charged at 12.1v, should be closer to 12.9v idle at rest, ~14v charging.
solution: get a new battery, whoever tested it good didnt know what they were doing.
It's drained so many times it can't be in the best shape... But I don't want to keep replacing batteries if I'm losing to a draw elsewhere ... Battery is 2-3 years old, duralast platinum iif i remember
sorry I used the word idle incorrectly, too much baggage.. A good battery should be doing ~12.9-13.2v with no loads and with no charge (engine off), in a resting state..
3 years for a battery is pretty typical depending on your climate and driving habits.. sometimes I can get 4 out of em.
If a battery has an internal failure like this they will self discharge rapidly, as soon as you take it off a charger they start shedding volts til they are flat again.. but for a while they are still capable of starting a vehicle, so the monkey at advanced auto would be able to pull enough amps to start it no problem if he ignored the glaring voltage issues.. you coulda turned the key and figured that out.
The people at your local Advanced Auto are not trained to operate any tools, including the one between their ears.
My 2009 avant has a type 49 AGM battery under the spare tire. It's 10 years old.
If I remove the spare and measure between the posts of the installed battery, I read 12.42v.
If I open the hood and read between the positive post under the plenum cover and the alternator housing, I read 12.42v.
These are with the ignition and engine off.
VCDS reports my state of charge as 85% (normal, seems Audi doesn't try and push the charging of the battery back to 100% SOC) and load aging around 55%.
12.1v on an unloaded battery is nearly no state of charge (SOC).
Take it out of the car and put it on a charger and see if it can get back to 12.7v (the starting point for 100% SOC).
You may or may not have the tool for it, but I'd put an ammeter between the battery negative post and the cable that would go on the negative post and see how much current draw you have. Same for with the ignition on. BUT DO NOT try to crank the car with an ammeter inline.
It could be you have an excessive draw by a component that's only on when the engine is running, or maybe your alternator is simply not producing enough recharge, if the battery was able to charge up isolated from the car.
At 12.4 v no load the battery is failing. There are 6 cells in the battery with each cell measuring 2.1 volts thus a fully charged battery should be 12.6 Volts. If you get 10 years on a battery you are lucky with todays cars drain on the electrical system. Voltage at idle should be between 13.8 to 14.4 and depending on what type of charging system you have it will vary. AGM batteries charge differently then flood type batteries so when you charge it make sure your charger can charge AGM type .
its actually 2.2v per cell, so 13.2v is a fully charged new battery..
SMac lives in Georgia, people in the southern states can get batteries to last alot longer than those of us with actual winters.. aint nobody getting 10 years out of a battery here in Colorado..
You may or may not have the tool for it, but I'd put an ammeter between the battery negative post and the cable that would go on the negative post and see how much current draw you have. BUT DO NOT try to crank the car with an ammeter inline.
![](http://carbatteryworld.com/wp-content/uploads/2013/01/Car-Battery-Voltage-Chart.jpg)
In part from Optima at: https://www.optimabatteries.com/en-u...mber-batteries
Even though our batteries are commonly referred to as "12-volt" batteries, if you measure your voltage with a multimeter and it reads "12.00" volts, your battery is actually significantly discharged. (emphasis added for this sentence only)
Fully-charged, our REDTOPs (including 34M BLUETOP) will read approximately 12.6-12.8 volts and our YELLOWTOPs will read approximately 13.0-13.2 volts (including BLUETOPs with light gray cases). When any 12-volt battery is discharged below 12.4 volts, sulfation begins to occur within the battery. Over time, this sulfation will diminish both the performance and lifespan of the battery.
