Last edit by: IB Advertising
- Audi A4 B8 Why Does Steering Wheel Shudder at Low Speeds<br>Guide to diagnose trouble and recommended solutions.
Weird steering wheel shudder/noise at extremely slow speed??!
#21
Definitely interesting. Mobilehavoc, the uk article you linked to states dynamic steering is "available" on all models 190ps (200hp?) and greater. At the same time, Audi's site states it is available only on vehicles with Drive Select http://www.audiusa.com/com/brand/en/...g.browser.html
I always thought our non-Drive Select cars don't have dynamic steering and have basic servotronic http://www.audiusa.com/com/brand/en/...c.browser.html steering.
Based on how dynamic steering operates, it seems almost possible that at low speeds, the shuddering sensation could be coming from the inner ellipse connecting and disconnecting with the outer steering gear...but then, if non-drive select vehicles don't have dynamic steering, not sure where the fault could be except from the PS pump.
#22
Maybe someone who's driven an A4 with ADS and without can chime in but I'm pretty sure all our cars have what is outlined in the articles/video except only ADS allows you to customize it.
#23
did another search on this forum and found
https://www.audiworld.com/forums/sho...speed+steering
I'm guessing we don't get the dynamic ratio steering without ADS but still get servotronic's power steering level speed adjustments. There was one other post that related the shuddering to the central diff. But then, why doesn't it occur on my wife's B7 and (for me at least) why does it occur mainly when the car is cold?
Btw, mobilehavoc, nice choice in vehicle...didn't notice the specs in your signature until now...basically same options on my end without the tips. Sad part though, where I am in ny/nj, just about every B8 on the road is black. Bittersweet impressions of comradery and lack of exclusivity.
#24
I experience the same thing, only at stand still or a couple mph pulling out of my driveway. Strangely, I've never noticed it after the car has effectively been "warmed up" but I'll try to pay attention from now on to see if it's only something that occurs at start up.
#25
I believe this goes works the same with transmission/suspension and ADS too...the "Auto" setting on those is the same as having a car without ADS. The advantage of ADS is being able to change those to "Dynamic", "Comfort" or "Individual"....which you obviously can't do without ADS.
Thanks, I'm in NY/NJ too and I've seen a couple of Silver, Grey and White 2009 A4s actually so not too bad but yes Black is popular color. Strangely (to me), quite a few 2009 A4s I've seen have been Premium trim (no LED DRLs).
#26
Maybe the car is just overly sensitive to road surface??!?!?!
#27
Actually, if it is a PS issue, it may make sense that the shudder is more prominent on rough surfaces that require greater force to turn the wheel. I took a look under the hood and it's just great that the power steering reservoir happens to be opaque.
As well, not sure if it's the same issue, but pushing the car a little into a curve (eg. rt3 west to parkway south when there's no traffic), there is also a faint shudder, though at this point I'm hoping it's because of the tires and not a weak PS pump.
#28
The reason I don't think it's a PS issue (or I hope it isn't) is because I just had the 5k service done about 300 miles (2 weeks) ago and they check all fluids, etc. Also the issue wasn't as prominent, although it existed, prior to the 5K service. You know what else they do at 5K service?? Rotate the tires....which is why I think it's the tires and sensitivity to road surfaces rather than PS issue.
#30
At first i glanced over this topic, but now that i'm reading this third page i'm starting to think of something that happens in my car quite frequently. Above, many of you have mentioned rough road surface, which got me thinking of a shudder i seem to get maybe once a week or so, however it is not constant like i think what some of you guys are getting. The first time it happened, i thought it was a flat tire, in the front right. Even my passengers felt it. Not only did the steering wheel shake, it seemed like the whole car reverberated a little, and it must have if my passengers mentioned something to me (i had already been aware something was up though). However, my tire monitors didn't post any message, the road was newly paved, i was going a steady 75 on cruise control. I stopped, did not see anything. I drove on- it came back, but then went away. This comes and goes, maybe once a week, more or less, on no particular road, usually lasting for a mile or two at the very most. I have just learned to expect it. I don't think this is what you guys are experiencing, but i thought i would share anyways.
