What brand of coolant?
My coolant is below min and what brand of coolant should I use?
The factory recommend to use 12++ coolant. My local shop showed me something that says for all maker/all model cars. It's yellowish coolant, but my car has pinkish coolant.
What do you guys use for top off?
Thanks
Thanks
Thanks
Thanks
Never Follows
Owners manual....
"Use only anti-freeze additive G12++, an additive meeting the
specification “TL 774 G”. Other additives may give considerably
inferior corrosion protection. The resulting corrosion in the cooling
system can lead to a loss of coolant, causing serious damage to the engine"
Dexcool does NOT meet VW's TL-774 standard.
My suggestion is to stay with what is recommended by the manufacturer.
You'll be in for a big ($$$$$) surprise when you start mixing and matching coolants in these cars.
VW or Audi dealers sometimes sell small topping-off bottles. You can also purchase the stuff (G12++) from NAPA under the Pentosin name plate.
^^ True! But it's suggested to use distilled water. Chemicals added to tap water could cause harm to engine parts/hoses.
G13 is the new standard with Audi vehicles it can be mixed with regular G12 G12+ and G12++
Be sure to check out our full line of engine coolant below!
Click HERE to order or for more information.
![](http://www.ecstuning.com/groupheaders/img/Coolant_Cooling_G12_G12_plus_G13_Antifreeze_Purple_Pink_Pentosin_Vaico_Organic_Acid_Technology_OAT_HOAT_Hybrid_Silicates_Phosphates_VW_Volkswagen_Audi_A3_Allroad_A4_RS4_S4_A5_S5_A6_S6_A8_S8_Q5_Q7_R8_RS6_TT_CC_EOS_Golf_MKIII_MKIV_MKV_MKVI_Jetta.jpg)
Jason
Jason
I've just placed an order from ECSTuning. It should be here tomorrow. Dealer's price is ridiculus.
Jason
Jason
