Xenon Lamp go out in 70 seconds
When I turn on my A4, Xenon Lamp (passenger side) goes out in 70 seconds.
I managed to install new Xenon bulb (Philips D1S) , but this problem still happen.
Should I ballast?
Thank you..
Should I ballast?
Thank you..
Which side of car is this photo? The bulb says D3S 35w on the bottom here? Is this not the right one?
The D1S bulb is impossible to fit into a D3S bulb holder without modifying the bulb base. Did you do anything unusual like forcing it in?
Thank you. It bought wrong one.
Thanks to your advice, I checked broken Zenon and it was D3S.
After D3S, the turn-off problem was solved. Thank you.
Mike Zamarocy
Motorsport Discussion
07-21-1999 06:04 PM
