2017 A4 coding tweaks
#1051
#1054
#1056
- A wrench with a beep at start/stop ignition. It's a reminder of oil service. Can be removed in MMI menu. Vehicle>Service and control>Oil interval reset
- A wrench without any beep. A reminder for 30k km. That can be removed easily with OBDELEVEN. It has an "application": Inspection service reset.
Regards,
Pato
#1057
Thanks
#1059
That’s good, let us know if it codes the mmi if not I’ll dig out the coding I used with OBDeleven, the instructions I got from kufatec were sit in car all doors bonnet boot shut, ignition on for one minute then plug dongle into ODB red light on when it goes green your done.
just don’t panic at all the warning messages that flash up as it’s doing it’s stuff, I thought I had killed my car 😃
I received mine yesterday and did the coding. It went well and MMI restart. After that I tested it by driving around, it didn't show me anything. This morning I drove again and now it shows me the speed limits signs only and only for a second or less and then it goes away. I drove all the way to work (about 25 minutes) and it kept on showing me only speed limit signs nothing else and even those only showed up for less than a sec and went away. Is it normal? I had some OBD coding before, but that shouldn't made a difference since dongle is supposed to take care of everything, right?
Anyone else having the same issue? Anyway else has tried the dongle?
#1060
