2017 A4 coding tweaks
Old 10-27-2018, 06:18 AM
  #1201
karsavuran's Avatar
anyone coded laptimer on NON-VC instrument? I coded but it does not show.
Old 10-29-2018, 10:21 PM
  #1202
asinla's Avatar
I’d like to know if anyone has successfully done this too.
Old 10-30-2018, 02:14 PM
  #1203
PatoAparato's Avatar
Hi,
In addition to the coding, you must have installed the multifunction plus steering wheel.
To​​​​ access the lap timer menu, you have to press ")" button:
Pato
Old 11-04-2018, 09:56 AM
  #1204
karsavuran's Avatar
Originally Posted by PatoAparato
Hi,
Pato
I have that button, and tried pressing it. But menu does not come.
Old 11-04-2018, 09:58 AM
  #1205
VipinLJ's Avatar
It should ideally be seen when u hit the left drawer button with the screen showing the car info display. It doesn’t work on radio, nav, phone displays. When u hit the left drawer button, you should see three options with the last being lap timer.
Old 11-04-2018, 10:02 AM
  #1206
karsavuran's Avatar
on non-vc instrument, right?
I mean if you are sure it works on non-vc instrument, then there is a problem on my coding.
Old 11-04-2018, 11:17 AM
  #1207
I've got mine working and I don't have VC installed.
Just select the far left tab with the arrows, press the aforementioned button ")" and choose the lap timer option.
Regards,
​​​​​​P
Old 11-04-2018, 11:19 AM
  #1208
karsavuran's Avatar
Regards,
​​​​​​P
Thanks, did you activate it under "adaptation", or just activate bit 3 of byte 1 under long coding?
Old 11-04-2018, 11:36 AM
  #1209
Sorry! I can't remember but here you are my notes:
Enable Laptimer shown in DIS
[17 – Instrument Cluster] [Coding – 07]
Select Long Coding Helper
Write down coding as backup
Select byte 01
Enable bit 03
Old 11-04-2018, 11:38 AM
  #1210
karsavuran's Avatar
Select byte 01
Enable bit 03
I also did that. I used a clone VCP but I was able to code needle swap. I do not understand what I am missing.
Quick Reply: 2017 A4 coding tweaks
