2017 A4 coding tweaks
#171
AudiA4B6US
I just came across a blog post from VCP on their release notes for 7.0 and part of the release contains scripts for VZE in the 4M Q7. Is there a way for you to access that and send it on or relay the contents? Here is the link it's at the very bottom.
VAG CAN PRO
VAG CAN PRO
#172
The scripts that VCP uses cannot be read, they are encrypted and executed in the background. The only option would be to take a car without VZE, do a full before scan, then run the VZE script, do an after scan and see how the coding and/or adaption has changed.
#173
Great, how fun and mysterious. Any thoughts on what's causing the disconnect of the traffic messages from reaching the VC?
#174
For those who are interested (VCDS 16.8.2, US A4 Prestige with all options, some values are not factory defaults anymore)
Coding
A5: 0404090100000202022023A6AD0000FCB0F0C020C020
5F: 019401020000000053220002041A00102F0002E501700104BE
Adaptation:
;SW:8W0-907-217-A HW:8W0-907-217 --- Frt Sens. Drv. Assist
;Component:BVS H14 0030, Coding:0404090100000202022023A6AD0000FCB0F0C020C02 0
;EV_BVSMLBevKOSTAAU736,002022,EV_BVSMLBevKOSTAAU73 6_AU49.rod
;Tuesday,11,October,2016,15:26:25:14336
;VCDS Version: Release 16.8.2 (x64) Data version: 20160926 DS261.0
;VCID: 3A38F6B5BD679992BA-806E
IDE02066-Windshield heat. direct. stabilize. assist. activation duration,2 min
IDE02332-Deactivate production mode,0
IDE04726-Intervention moment,Selection via menu
IDE05984-Directional stabilization assist driver inact deactiv threshold,Medium
IDE05985-Directional stab. assist.: intensity: steering wheel vibration,Medium
IDE05986-Directional stab. assist.: intensity: power steering support,Medium
IDE06425-Roller test bench mode: functional,not activated
IDE07358-Distance to calibration field,1500.00 mm
IDE07596-Personalization of lane dept. warning Cl. 15 on,Last setting
IDE08447-Driving axis angle,0 '
IDE09375-IDE05717-Axle offset-Front axle transverse position,0.30 mm
IDE09375-IDE05718-Axle offset-Rear axle transverse position,3.90 mm
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,710.50 mm
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,713.50 mm
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,695.00 mm
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,696.50 mm
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2429.00 mm
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,743.00 mm
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1497.00 mm
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2429.00 mm
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-743.00 mm
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1497.00 mm
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2429.00 mm
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,743.00 mm
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,903.00 mm
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2429.00 mm
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-743.00 mm
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,903.00 mm
MAS05331-IDE03355-Calibration result-Static calibration: yaw angle,352.32 °
MAS05331-IDE03356-Calibration result-Static calibration: pitch angle,0.23 °
MAS05331-IDE03357-Calibration result-Static calibration: roll angle,-0.71 °
MAS05331-IDE03358-Calibration result-Static calibration: camera height,21774 mm
Elapsed Time: 00:14
;SW:8W0-035-880-B HW:8W0-035-880 --- Information Electr.
;Component:MU-P-LNS-US 051 0443, Coding:019401020000000053220002041A00102F0002E5017 00104BE
;EV_MUHig6C3Gen2HBAS,001115,EV_MUHig6C3Gen2HBAS_AU 37.rod
;Tuesday,11,October,2016,15:28:06:14336
;VCID: 393AE9B9B861928AB3-806C
IDE00001-Production mode,00 00 00
IDE00346-Summertime-automatic,automatic
IDE00759-Base volume of speech output,50 %
IDE00768-Country identification: country of sale,US
IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
IDE00845-Wheel circ.,0 mm
IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes
IDE01996-ENG99724-Installation list: specified installations-ECU coded,No
IDE01996-ENG06573-Installation list: specified installations-ECU coded 2,No
IDE02121-CD eject button,Enabled
IDE02122-Developer mode,not activated
IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,32
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,85
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,85
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,85
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,85
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,85
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,85
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,85
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,17
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,17
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,32
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,85
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,85
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,85
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,85
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,85
IDE02502-Confirmation of installation change,30 73
IDE02506-MAS03229-Copy multimedia data-Data medium,On
IDE02506-MAS03230-Copy multimedia data-Optical drive,On
IDE02607-Wheel pulse,0
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,On
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,On
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,On
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present
IDE03471-ENG127492-Vehicle configuration-LGI,OFF
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated
IDE03471-ENG07590-Vehicle configuration-Mirror_link,function_on_hmi_on
IDE03471-ENG117843-Vehicle configuration-my_audi,On
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF
IDE03471-ENG127495-Vehicle configuration-online_media,On
IDE03471-ENG117840-Vehicle configuration-online_navigation,On
IDE03471-ENG117837-Vehicle configuration-online_POI,On
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On
IDE03471-ENG117841-Vehicle configuration-online_street_view,On
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act.
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF
IDE03471-ENG06574-Vehicle configuration-ProbeCar_vzo,OFF
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On
IDE03471-ENG07589-Vehicle configuration-RSE_software_component,activated
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,LVDS
IDE03471-ENG11009-Vehicle configuration-sd_slot_deactivation,no restriction
IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag,no_region
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,present
IDE03471-ENG07591-Vehicle configuration-Smartphone_interface_for_rhmi,activated
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF
IDE03471-ENG06575-Vehicle configuration-UOTA,On
IDE03471-ENG117852-Vehicle configuration-UPnP,On
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF
IDE03471-ENG127494-Vehicle configuration-VZO,OFF
IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI,On
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On
IDE03580-Country code for mobile network,0
IDE03902-Automatic ring break diagnostic,No automatic start
IDE04292-Roadside assistance mode,Corresponding setting in MMI
IDE04294-Number attempted dialing attempts for roadside assistance,3
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,1
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,1
IDE04521-Sporadic ring break detection,Visual
IDE04522-Awakening ability on optical databus,OFF
IDE04549-Telephone data services,On
IDE04550-Bluetooth: Sniff mode,On
IDE05111-Fee-based traffic information (TMC),65533
IDE05113-Infotainment Recorder,activated
IDE06697-Audio management mute function,Muting of audio sources
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,17
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,7
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128
IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated
IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated
IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated
IDE10668-Internal SIM card: use,automatic
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,20 dBµV
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,50 dB
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,0.1 s
IDE11105-Brand-specific display of connect application,de.audi.mmiconnect
IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767
IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535
IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295
IDE11503-Tuner for satellite radio: preparation,05
IDE11638-Bluetooth Audio Codec,FF
MAS00951-Bluetooth,On
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz
MAS03690-Telephone,Data & language service active
MAS03782-WLAN,On
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,On
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,150.00 ms
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,On
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,150.00 ms
ENG117920-Audio_Managment_Soundset_Menu,OFF
ENG117917-BAP_Debug_Mode_Release,not_released
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,n ot activated
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,acti vated
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer ,not activated
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_h igh,activated
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,no t activated
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_discla imer,not activated
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off ,not activated
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_thresho ld_high,not activated
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,n ot activated
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,no t activated
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high ,not activated
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,n ot activated
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_hig h,not activated
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,ac tivated
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,no t activated
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,a ctivated
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer, not activated
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_hi gh,activated
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activate d
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer, not activated
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_hi gh,activated
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated
ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaime r,not activated
ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,no t activated
ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_ high,not activated
ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,no t activated
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,activated
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,no t activated
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high ,activated
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,activated
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaime r,not activated
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,no t activated
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_ high,activated
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,activated
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,ac tivated
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,ac tivated
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaim er,not activated
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,n ot activated
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold _high,activated
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activat ed
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,no t activated
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high ,not activated
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaime r,not activated
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,no t activated
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_ high,not activated
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_discla imer,not activated
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off ,not activated
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_thresho ld_high,activated
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,n ot activated
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_discla imer,not activated
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off ,not activated
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high,activated
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,n ot activated
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,n ot activated
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_hig h,activated
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,no t activated
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,no t activated
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high ,not activated
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated
ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated
ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated
ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated
ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,n ot activated
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_hig h,not activated
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,no t activated
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high ,not activated
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,activated
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,n ot activated
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaime r,not activated
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,no t activated
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_ high,not activated
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated
ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated
ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated
ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated
ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Databus Infotainment
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,CAB_4
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,activated
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Databus Infotainment
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Terminal 15
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,activated
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,activated
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Databus Infotainment
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,activated
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Terminal 15
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Terminal 15
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Termin al 15
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated
ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated
ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated
ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated
ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal 15
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,activated
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Terminal 15
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Available
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Terminal 15
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15
ENG122230-ENG11025-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,LVDS_map_FP K
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,On
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,LVDS_map_FPK
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_U nit-X1,0
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_U nit-X2,50
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_U nit-X3,100
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_U nit-Y1,0
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_U nit-Y2,50
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_U nit-Y3,100
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,20
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,7 %
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,16 %
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed
ENG117809-p_damping_Display,5 ms
ENG117808-p_HMI_Display,10 %
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h
Elapsed Time: 00:42
Coding
Adaptation:
Elapsed Time: 00:14
MAS03782-WLAN,On
Elapsed Time: 00:42
#175
Code:
Coding A5: 0404090100000202022023A6AD0000FCB0F0C020C020 5F: 019401020000000053220002041A00102F0002E501700104BE Adaptation: ;SW:8W0-907-217-A HW:8W0-907-217 --- Frt Sens. Drv. Assist ;Component:BVS H14 0030, Coding:0404090100000202022023A6AD0000FCB0F0C020C020 ;EV_BVSMLBevKOSTAAU736,002022,EV_BVSMLBevKOSTAAU736_AU49.rod ;Tuesday,11,October,2016,15:26:25:14336 ;VCDS Version: Release 16.8.2 (x64) Data version: 20160926 DS261.0 ;VCID: 3A38F6B5BD679992BA-806E IDE02066-Windshield heat. direct. stabilize. assist. activation duration,2 min IDE02332-Deactivate production mode,0 IDE04726-Intervention moment,Selection via menu IDE05984-Directional stabilization assist driver inact deactiv threshold,Medium IDE05985-Directional stab. assist.: intensity: steering wheel vibration,Medium IDE05986-Directional stab. assist.: intensity: power steering support,Medium IDE06425-Roller test bench mode: functional,not activated IDE07358-Distance to calibration field,1500.00 mm IDE07596-Personalization of lane dept. warning Cl. 15 on,Last setting IDE08447-Driving axis angle,0 ' IDE09375-IDE05717-Axle offset-Front axle transverse position,0.30 mm IDE09375-IDE05718-Axle offset-Rear axle transverse position,3.90 mm IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,710.50 mm IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,713.50 mm IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,695.00 mm IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,696.50 mm IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2429.00 mm IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,743.00 mm IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1497.00 mm IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2429.00 mm IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-743.00 mm IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1497.00 mm IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2429.00 mm IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,743.00 mm IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,903.00 mm IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2429.00 mm IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-743.00 mm IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,903.00 mm MAS05331-IDE03355-Calibration result-Static calibration: yaw angle,352.32 ° MAS05331-IDE03356-Calibration result-Static calibration: pitch angle,0.23 ° MAS05331-IDE03357-Calibration result-Static calibration: roll angle,-0.71 ° MAS05331-IDE03358-Calibration result-Static calibration: camera height,21774 mm Elapsed Time: 00:14 ;SW:8W0-035-880-B HW:8W0-035-880 --- Information Electr. ;Component:MU-P-LNS-US 051 0443, Coding:019401020000000053220002041A00102F0002E501700104BE ;EV_MUHig6C3Gen2HBAS,001115,EV_MUHig6C3Gen2HBAS_AU37.rod ;Tuesday,11,October,2016,15:28:06:14336 ;VCDS Version: Release 16.8.2 (x64) Data version: 20160926 DS261.0 ;VCID: 393AE9B9B861928AB3-806C IDE00001-Production mode,00 00 00 IDE00346-Summertime-automatic,automatic IDE00759-Base volume of speech output,50 % IDE00768-Country identification: country of sale,US IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF IDE00845-Wheel circ.,0 mm IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes IDE01996-ENG99724-Installation list: specified installations-ECU coded,No IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes IDE01996-ENG99724-Installation list: specified installations-ECU coded,No IDE01996-ENG99724-Installation list: specified installations-ECU coded,No IDE01996-ENG99724-Installation list: specified installations-ECU coded,No IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes IDE01996-ENG99724-Installation list: specified installations-ECU coded,No IDE01996-ENG06573-Installation list: specified installations-ECU coded 2,No IDE01996-ENG06573-Installation list: specified installations-ECU coded 2,No IDE01996-ENG06573-Installation list: specified installations-ECU coded 2,No IDE01996-ENG06573-Installation list: specified installations-ECU coded 2,No IDE01996-ENG06573-Installation list: specified installations-ECU coded 2,No IDE02121-CD eject button,Enabled IDE02122-Developer mode,not activated IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 IDE02332-Deactivate production mode,0 IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,32 IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,85 IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,85 IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,85 IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,85 IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,85 IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,85 IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,85 IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,17 IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,17 IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,32 IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,85 IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,85 IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,85 IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,85 IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,85 IDE02502-Confirmation of installation change,30 73 IDE02506-MAS03229-Copy multimedia data-Data medium,On IDE02506-MAS03230-Copy multimedia data-Optical drive,On IDE02607-Wheel pulse,0 IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 IDE03471-ENG117847-Vehicle configuration-advanced_range_display,On IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On IDE03471-ENG130248-Vehicle configuration-Google_GAL,On IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,On IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,On IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present IDE03471-ENG127492-Vehicle configuration-LGI,OFF IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated IDE03471-ENG07590-Vehicle configuration-Mirror_link,function_on_hmi_on IDE03471-ENG117843-Vehicle configuration-my_audi,On IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF IDE03471-ENG127495-Vehicle configuration-online_media,On IDE03471-ENG117840-Vehicle configuration-online_navigation,On IDE03471-ENG117837-Vehicle configuration-online_POI,On IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On IDE03471-ENG117841-Vehicle configuration-online_street_view,On IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF IDE03471-ENG06574-Vehicle configuration-ProbeCar_vzo,OFF IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 IDE03471-ENG117846-Vehicle configuration-remote_HMI,On IDE03471-ENG07589-Vehicle configuration-RSE_software_component,activated IDE03471-ENG126143-Vehicle configuration-RVC_video_input,LVDS IDE03471-ENG11009-Vehicle configuration-sd_slot_deactivation,no restriction IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag,no_region IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,present IDE03471-ENG07591-Vehicle configuration-Smartphone_interface_for_rhmi,activated IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF IDE03471-ENG06575-Vehicle configuration-UOTA,On IDE03471-ENG117852-Vehicle configuration-UPnP,On IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF IDE03471-ENG127494-Vehicle configuration-VZO,OFF IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI,On IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On IDE03580-Country code for mobile network,0 IDE03902-Automatic ring break diagnostic,No automatic start IDE04292-Roadside assistance mode,Corresponding setting in MMI IDE04294-Number attempted dialing attempts for roadside assistance,3 IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP IDE04298-MAS01779-Vehicle dimensions-Length,0 mm IDE04298-MAS01780-Vehicle dimensions-Width,0 mm IDE04298-MAS02230-Vehicle dimensions-Height,0 mm IDE04331-Selection of release codes for a SWaP function,FF FF FF FF IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,1 IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,1 IDE04521-Sporadic ring break detection,Visual IDE04522-Awakening ability on optical databus,OFF IDE04549-Telephone data services,On IDE04550-Bluetooth: Sniff mode,On IDE05111-Fee-based traffic information (TMC),65533 IDE05113-Infotainment Recorder,activated IDE06697-Audio management mute function,Muting of audio sources IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,17 IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,7 IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated IDE10668-Internal SIM card: use,automatic IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,20 dBµV IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,50 dB IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,0.1 s IDE11105-Brand-specific display of connect application,de.audi.mmiconnect IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535 IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295 IDE11503-Tuner for satellite radio: preparation,05 IDE11638-Bluetooth Audio Codec,FF MAS00951-Bluetooth,On MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz MAS03690-Telephone,Data & language service active MAS03782-WLAN,On ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,On ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,150.00 ms ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,On ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,150.00 ms ENG117920-Audio_Managment_Soundset_Menu,OFF ENG117917-BAP_Debug_Mode_Release,not_released ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,activated ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,activated ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,activated ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,activated ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,activated ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15 ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15 ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15 ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Databus Infotainment ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,CAB_4 ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,activated ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Databus Infotainment ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Terminal 15 ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,activated ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,activated ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Databus Infotainment ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15 ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,activated ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Terminal 15 ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15 ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Terminal 15 ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15 ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Terminal 15 ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15 ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15 ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15 ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,activated ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15 ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15 ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Terminal 15 ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Available ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Terminal 15 ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15 ENG122230-ENG11025-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1 ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,LVDS_map_FPK ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,On ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1 ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,LVDS_map_FPK ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,20 ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 % ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 % ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,7 % ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,16 % ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 % ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 % ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ENG117809-p_damping_Display,5 ms ENG117808-p_HMI_Display,10 % ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0 ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0 ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h Elapsed Time: 00:42
#178
It self steers I haven't been daring enough to test the vibration. But I think all steering wheels can do it as they don't build in motors anymore but it is part of the steering column I believe.
#180
So I guess you have all of the DAP except for adaptive cruise control without having to get prestige trim?
