2017 A4 coding tweaks
#232
I may be able to help with that. The Aus spec has the bottom DRL on by default when indicating so it certainly looks doable. I have the standard non-matrix LED headlights.
Having a poke around, there's a setting on mine in Module 9 -> Coding -> drl_at_indication_config -> full_available. Maybe?
#233
#234
Backup name: module 9
Long coding:
07501943E17900CD011587141B2C08F9110331000000000000 000000200016810A450123025705
This was the output dump from obd after doing the backup of module 9. I can't work out out how get further information, but if there's a way to do it, I'd be glad to try.
Long coding:
#235
Long coding:
Long coding:
#236
But in module 9, it only gave the full coding with no adaptations list. Might be a bug or something yet to be implemented by the folks at obdeleven.
heh, time zones!
#237
You guys have done awesome work!
I just ordered OBDeleven and wondering if someone else have small MMI without original navi. I have a basic MMI and option to add navi by dealer. Done that, but there is no map display in FIS, only in MMI. Find this wiki info and wondering does it works only with original navi or also with navi option, which is released (dealer add SD card and release function).
https://translate.google.fi/translat...MMI_aktivieren
#238
Wondering if anyone had any luck getting traffic sign recognition. I know Mitch has been working on it.
Will there be any harm done if I go ahead and enable anything with the word "traffic" and "sign" in OBDEleven under all the menus
I know it probably won't work but just curious to see what faults I get.
#239
