2017 A4 coding tweaks
Old 10-25-2016, 08:19 AM
  #311
Mitchfin's Avatar
Originally Posted by KevinB656
What exactly does this do?
As you pull up to objects in drive the parking system will automatically start.
Old 10-25-2016, 10:21 AM
  #312
Mitchfin's Avatar
Here is a lighting diagram for the taillights, if someone wants to start cracking, all these numbers coincide with PWM numbers in module 46 and have 3 different values attached to them, (A4B6US you'll recognize these) I don't know the security code for 46 however and I believe you need them to change anything. And just so you all know #6 and #11 are the brake light, but its also the top part of the dynamic turn signal, so I don't know how we will get the brake light to go off while the other stays on during signaling.
Here is the breakdown so there is no confusion:
2: Driver side reverse
3: Driver side signature light (the "C" body segment)
4: Driver side signature light (trunk segment)
5: Passenger side dynamic turn signal segment (trunk)
6: Passenger side brake light/upper dynamic turn signal segment
8: Driver side rear fog light
9: Passenger side reverse
10: Passenger side signature light (the "C" body segment)
11: Driver side brake light/upper dynamic turn signal segment
14: Passenger side signature light (trunk segment)
15: Driver side dynamic turn signal segment (trunk)
16: Passenger side rear fog light
17: High mount brake light
Andrew C. (11-27-2021)
Old 10-25-2016, 01:41 PM
  #313
RickObe's Avatar
What he said.
Also, in the more recent builds (for the Q7 at least), this function was already enabled. So depending on how recently your car was built, you may not need this coding to have front parking sensors come on automatically.
Old 10-25-2016, 03:26 PM
  #314
DirkM's Avatar
Great post! I didn't touch those (yet) and I'm still waiting for erwin to have wiring diagrams for the US B9 (Q7 4M are out there but they were not mom much use) so that I can see if they are hard wired together (somehow). Shouldn't, because the turn signals are dynamic but who knows. VCP has some scripts to change the rear lights from NAR to ROW and vv. but that didn't do anything when I tried it (didn't ask for a code though). I'm also eying some ROW rear LEDs from DE as Christmas present to myself, the amber turn signal are just so much better.
Old 10-25-2016, 06:18 PM
  #315
Mitchfin's Avatar
Do you think it's hardware based?
Old 10-26-2016, 02:28 AM
  #316
DirkM's Avatar
Hard to say without wiring plan.
Old 10-26-2016, 01:38 PM
  #317
DirkM's Avatar
On the topic of making Lane Assist wait a little longer before it starts bothering the driver, this might help (mo time right now to test this myself and no idea how this looks in OBE11):
STG A5 - Frt Sens. Drv. Assist - Adaptation
2. ORIGINAL - UDS Adaptation Channel: IDE05984-Directional stabilization assist driver inact deactiv threshold
Stored value Medium
2. MOD - UDS Adaptation Channel: IDE05984-Directional stabilization assist driver inact deactiv threshold
Stored value Late
2017 Audi Q7 4M - Adaptations, Coding & Modifications
Old 10-26-2016, 01:41 PM
  #318
DirkM's Avatar
And another one, not sure if that's of any use:
STG 5F - Coding - enable "byte_24_VZA" (OBD11?) to run on (nav data based) speed signs in the MMI if VZE is enabled in the VC/HUD
Codierungen - allgemeine Diskussion Seite 89 : Selbe Situation hatte ich eben. A1, Baustelle 2,10m breit (lin...
Old 10-26-2016, 01:48 PM
  #319
Mitchfin's Avatar
Have tried that it doesn't work unfortunately but on a positive note, I have no idea how I did it cause it just started doing this randomly but my VC always starts on the last page I was on now (aka. Straight to maps)
Old 10-26-2016, 01:49 PM
  #320
DirkM's Avatar
LOL, I now that feeling...
Quick Reply: 2017 A4 coding tweaks
