2017 A4 coding tweaks
#421
BTW, there was also an option called fuel replenishment under the dashboard (CM 17) module I believe. Has anyone tried activating that? In my VWs, what that does is show how much fuel needs to be filled up for a full tank. Didn't try it on my A4 B9 though.
#422
Interesting. Try turning it on and let us know what it looks like.
#424
Tried to change "time for opening rear lid with remote control" by using
46 Central module
adaption
default 2000ms, changed to 500ms
Noticed it affected the foot activated trunk release....
Before the success rate was 9/10, now it is 1/10
Anyone else getting this problem?
46 Central module
adaption
#425
Okay. I did back up each module but thought there was a way to back up all together.
And yes. I live in IL. My car is a US model. I don't have the driver assist package but I seem to have both options in my VC. Just curious since Mitchfin, I think, had to code it for the screens to pop up. My car is only a week old plus it was the newest car in the lot, if that helps. Maybe the new ines have some already activated and probably need only a new indicator stalk with the lane assist button? Who knows. I think there was a drivers assist option in the mmi too. Not sure.
Edit:
So these are the screens from my car. The drivers assist doesn't hav the grey lines and the traffic recognition thing didn't recognize stop and speed limit signs.
I remember going through the OBDeleven options and drivers assist or lane change or something of that sort was deactivated. I guess these options are present in all cars, just not activated depending on trim/package.
Drivers assist without the grey or green lines
Traffic sign recognition option
Edit:
Once I followed the guide, Active lane assist works, but it wasn't enabled prior to tweaking the code with my OBDEleven even though the screens for Active Lane Assist and Traffic Sign recognition were already on the screen.
#426
My car was built in September of this year and delivered to the dealership three weeks ago, it have both the options in the console that yours has, but I had to follow the guide to enable active lane assist. Nothing was enabled by default except one option that the guide said may already be active.
#427
Btw, how does one activate the lap timer using OBDeleven? I went to Controle module 17 (Dashboard). I saw Coding and Adaptations there. Both have an option called Lap counter. Didn't see a lap timer. When I clicked on lap counter under adaptations, there were three options - no display, display and not available. It was on no display. I changed it to display and clicked ok and it said adaptation accepted.
I then quit the software, switched off my car, removed the OBDeleven, switched on my car and I couldn't find the lap timer option in the first screen with the mpg counter, energy consumer counter and stuff. There was also that red tab only on the right side of the VC. No red tab on the left. So I went back on OBDeleven and changed the adaptation back to no display (which was how it was), clicked ok and it said adaptation accepted. Wonder what I did wrong?
#428
#429
If the lap timer has not been enabled, there will be no left tab displayed. So you have not enabled the lap timer yet. To enable the lap timer you must select lap counter in long coding and change the value to yes. and then don't forget to tap the green checkmark at the bottom right corner of the OBD 11 display. If you do not tap the green checkmark icon the coding has not yet been accepted.
#430
Btw, has anyone tried changing the trunk opening duration using key from the standard 800ms to longer? I read that a few people did that and then couldn't open the trunk using the hands free method. Anyone faced that issue here?
