2017 A4 coding tweaks
#51
For example, VCP lists a coding "sidemarker_via_lcm" which could mean anything and is active in NAR. Turning this off will turn off the little yellow LED in the headlights, after that is confirmed it's just figuring out that it's Byte 6 Bit 1 that has to be unchecked to turn the LED off. Knowing what to change either VCDS or VCP can be used to make that change.
Now I wish the rear LED lights would be that easy...
#52
You probably already know this. Have you tried the codes on at stemei.de .Fahrzeugcodierungen .Codierungsservice .Webdesign - Stefan Meier - Audi A4 8W - Fahrzeug Codierungen, Webdesign ?
The needle sweep and lap timer ones look pretty cool.
#53
#54
If you come across any of the Driver assist coding I'll happily be the test mule for high beam assist or traffic sign recognition
since lane assist needs extra parts those two seem like the easiest to enable and test.
#55
There is lots of coding but no direct instructions. Some day we have to meet and compare part numbers. You can even borrow the cable but I don't think I'm ready to brick your car just yet :-)
#56
Haha, it's just a car
I am ordering my cable this week, let me know if you want any part numbers. The one I want to know but can't get to is the front camera, I cannot get the housing off, it feels like I'm going to break it every time.
#57
VCDS or VCP? You could stop by before ordering and get the camera part number via cable, no disassembly required...
