2017 A4 coding tweaks
Old 05-06-2017, 08:30 PM
  #801
wdimagineer's Avatar
Originally Posted by ODIE-B9
haven't tried this but came across this coding
>> Rear Turn Signal: Disable the middle segment and leave only the top section ("winkers") active
What are the coding of:
[46 - Comfort System]
[Security Access - 16] -> Enter login-code: 16017
[Adaptation - 10] -> Channel 181 - 212
Wrong platform. Not possible on the B9. The top and middle segments are wired inside the lamp.
Old 05-08-2017, 08:39 PM
  #802
NewA4B9's Avatar
Originally Posted by AudiA4B6US
There are a few things that I would like to change but it will probably take a while before this will be figured out, if possible at all:
- Show gears in D/S - done
- enable ACC default distance setup in the MMI - done
- use personal data SIM for WiFi clients (t-mobile in my case) - done (Note: if using external SIM, all data will use the external SIM even the data used for Google Earth and other Audi Connect services)
- enable Hotspot and Client mode which apparently is not enabled by default - visible but not working
- turn off that ugly middle segment in the rear when using the turn signal
- keep the bottom DRL in the front on while using the turn signal
Enable Automatic Gear selection shown in DIS
[02 – Auto Trans] [Adaptation – 10]
Select “Single Gear Display” from top channel drop down menu
Select “D on/S on” from New value drop down menu
Enable Automatic PDC Front
[09 – Central Elect.] [Coding - 07]
Select Long Coding Helper
Select Bye 37
Check Bit 1
Exit Long Coding Helper
Click Do It
Enable ACC default distance in MMI (VCDS 16.6 or newer required)
[13 - Auto Dist. Reg][Adaptation - 10]
Select "Distance basic setting option" in dropdown
Select "On" from New value drop down
Save and reset MMI
Enable Laptimer shown in DIS
[17 – Instrument Cluster] [Coding – 07]
Write down coding as backup
Select byte 01
Enable bit 03
Increase time required to open trunk lid with remote key
[46 - Central Convenience][Adaptation - 10]
Scroll down and find channel "Time for opening rear lid with remote control"
Load Stored Value (should be 800 ms)
Enter new value in "ms". Example: 2000, Max: 5000
Click Do It
Double beep on opening (didn't work on my A4B9 after locking, waiting and unlocking, may need to wait longer)
Scroll down and find channel "sounder_settings-beeptime_opening_central_locking"
change from "no_beep" to "double_beep"
Click Do It
Not sure if this helps Canadian "non-AudiConnect" owner to enable the modem but might be worth a try
[5F - Information Electronics][Adaptation - 10]
Select "Vehicle configuration-LTE_module"
was "activated" in my US A4B9
Video in Motion, no disclaimer when entering destination while driving
Details not public yet but possible with VCP
Enabling Lane Assist in cars with Pre-Sense Front
Guide: Enable Google Earth/Traffic on Canada spec Audi
Thanks so much for this!!!
I got a few things done and I was trying to enable the Video in motion but I can't find the steps/codes anywhere, can you please help??
Old 05-09-2017, 01:56 AM
  #803
KevinB656's Avatar
I don't think anyone has the code for this. I highly recommend using OBDEleven Pro.
Old 05-09-2017, 04:08 AM
  #804
RmK_A5's Avatar
Anyone managed to get Traffic Sign Detection to work ?
Old 05-09-2017, 04:27 AM
  #805
KevinB656's Avatar
Mitchfin is the guru on these coding changes. He spent a lot of time trying to figure out traffic sign recognition coding and couldn't. At this point, I think he has admitted defeat and moved on.
Old 05-09-2017, 04:36 AM
  #806
RmK_A5's Avatar
Ahh, I hope he will manage to sort it out in the future
It's more "nice to have" than a necessity IMHO
Old 05-09-2017, 04:58 AM
  #807
KevinB656's Avatar
Agreed. Much of the time the speed limit shows up on the MMI navigation screen anyway.
Old 05-10-2017, 12:54 PM
  #808
NewA4B9's Avatar
Thanks Kevin,
Anybody in Edmonton, Alberta with an OBDEleven that can help me with this??
Old 05-12-2017, 09:29 AM
  #809
Howard Shure's Avatar
Hey guys. I've been combing through this thread and I can't thank the OP and everyone on here enough. This is some great stuff. I just picked up a 2017 A4 Season of Audi edition this past weekend. It came with Nav & MMI interface & Virtual Cockpit. Aside from Pre sense basic and city, I don't have any other driving/parking assist options. Based on this, am I able to use any of this coding to enable the Park Distance Control so I can tell how close I am in the front or back when parking? Or am I missing hardware needed for this? Thanks for all your hard work!
Old 05-12-2017, 09:53 AM
  #810
VipinLJ's Avatar
PDC uses the radar sensors on the bumper which every car has. It should work in your car without a problem. Funny that it isn't already activated since it came like that from the factory in my car.
Quick Reply: 2017 A4 coding tweaks
