Adaptive Headlights
Hello everyone! New to Audi and I am planning to get an 18' Audi A4 prestige. Just went for a test drive and was quite happy with the ride. There was one question my dealer couldn't answer and that was about adaptive headlights. AudiUSA says that the LED lights are auto leveling but make no mention about if they can turn based on the steering and direction the car is going. So, does the prestige trim have it or not?
Thanks
Thanks
Thanks
Thanks
I have an '18 Prestige and the headlights do not turn. I believe they have an element that adjusts the beams when turning. My other half had a BMW and a Lincoln that both had turning headlights and it was obvious. Others may be better equipped to chime in, I do mostly city/highway driving and haven't even used the high beams yet.
No they don't turn. When you're going slowly and either turn pretty sharply or use the turn signal, the fog light on that particular side illuminates.
Wow it's scary to think your dealer doesn't know the answer to such a rudimentary questions.... The answer is no. I'd be wary of any other important things you are taking your dealers word on if that can't even answer a simply product feature question....
Thanks
Thanks
Not sure Which country market you are. For US market, the LED headlights will not physically turn. However, each side of the all weather light will light up to the direction you turn into thus illuminating that direction (left or right, when the road is bend enough requires a substantial steeling wheel adjustment). The end effect is somewhat like headlight turnning. I love that feature.
I mean, European models only have "All weather" lights function. No cornering light effect (only available with Matrix LED), thus it's possible to code cornering lights IN EXCHANGE FOR button function. I coded the cornering function but now I can't activate both "all weather" lights as fog lights. Maybe we can fix this issue checking original coding for US vehicles.
Regards,
Pato
Can someone with OBDELEVEN post these parameters' values?
09 stg
Fog light configuration:
Static cornering light via foglightpin
Skl config:
Turn light r48
Skl outputs:
Skl via bcm
Thanks!
P.
