Adding a Sub and Amplifier to B&O problem
Hello Guys...
I am trying to add a sub and and amplifier to my B&O system but when connecting the high level outputs directly to the high level input to the amp it presents no load to the B&O amplifier so it will not output a signal...
How can I overcome this problem?
Thanks!
JC
Thanks!
JC
Hello Guys...
Thanks!
JC
Thanks!
JC
Sometimes its the simplest of things, but does the amp have a small switch on it that needs to be set between HIGH/LOW level input?
I would first run everything stock and measure the AC voltage on the sub-woofer, and check if your amp is capable of the range on the high level input.
On an alternate route, you could also get a LINE OUT CONVERTER
and just use the RCA input. Its an extra part, but they are pretty cheap.
Thanks for the response guys...
I disconnected from the oem sub high level wires but got no sound (voltage) output from the oem amp, when reconnecting directly to the sub sound restarted...
You need to have sub connected and running to measure the voltage. Its hard with the plug connected. It will not work with sub disconnected.
MM120
06-05-2002 07:48 AM
Bimmer Love
12-12-2001 10:03 PM
