Advice on best Audi year
#11
Ditto on the wastegate problem. The wastegate pivots on plain bearings with no replaceable bushings. It is a pure wear issue that results in the waste gate getting floppy and failing to seal. People sell a rebush kit to fix this problem on the B8 cars; but, no such fix exists for the B9.
Proper oil change intervals is good; but, it won't help dodge the wastegate problem.
#12
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
It seems to me that the only feasible way to own an A4 is to either buy it new, or as a CPO - in other words one that has warranty on it and then sell it right at the end of the warranty. And even then ... yes, you may not pay for repairs but still can't drive it when it's in the shop. As I plan to DIY pretty much everything, save for the alignment, it looks like this is not the car for me.
Oh well, it is what it is. I'll look at other brands.
#13
Even CPO is pretty poor at this point. Only worth 12 months or 20k miles under the current terms.
Besides, at least the wastegate actuator can be replaced on the A4/A5 versions of the Gen3evo 2.0T. Not so for the Q5 version. And you can on the Gen4 performance engine (the 45 engine), but not so on the Gen4 b-cycle engine (the 40 engine). Why? Who knows. Audi's control over the competency of its suppliers has been shot for years now.
black.cat (07-18-2024)
#15
Thanks for the heads-up guys ! Did a bit of reading on it myself and yeah ... hmmm, that's not good news for those who would like to use an A4 as a daily driver
So 2017-2019 models are scrapped from my list and the jury is still out on 2021 version.
The waste gate problem is not a fatal problem (the car can be driven) and it is not a high frequency problem. There are a lot of 2017 - 2020 A4s running around with their original IHI turbos. Also, in the days of $200+ dealership oil changes, it is not a particularly expensive problem if you are handy with wrenches. A complete new IHI turbo assembly along with the miscellaneous bits for installation can be had for $1000 and its probably a relaxed 1 day job to R&R for someone who has been around wrenches. It is just something to add in to the evaluation mix when looking at model year, car condition and price.
If reliability as a daily driver has the absolute highest ranking in your evaluation list, then a Lexus or a Toyota Camry might be a better choice. However, do check that Consumer Reports because reliability data does tend to change. Honda Accords are not what they used to be.
LightningTruck (07-07-2024)
#16
Put all the advice in context.
I had two Toyotas in the past: a Highlander (made in Japan) and a Corolla. I hated the Corolla - the seats were very uncomfortable (it was like sitting on a bench) and drove and handled like a boat. Sold the Corolla pretty quickly and got a Passat. The Highlander started to break once I passed 100K: the paint was flaking and flying off the chassis, the front differential was leaking, underbody rust everywhere (my 20 year old BMW 325 barely has any), a passenger window developed a crack and the power steering rack was leaking ... Sold it and got a Q7.
I think I had the Passat for 3 years till I noticed the early warnings of sludge developing (I wasn't a DIY-er at that time, but I wasn't lazy with oil change either - must have been the way the previous owner took care of it). Anyway, I sold it and bought my first bimmer which really got me into DIY. Owned four bimmers since then, still have two, and save for installing new tires and alignment, I've done all maintenance myself (full cooling overhauls, full front and rear suspensions overhauls, wheel bearings, engine mounts, fluids, vanos, injectors, fuel filters and other staff). On the Q7 so far I've only changed the belt and tensioners, diff and transfer case fluids and getting ready to do the valve cover gasket and a tranny drain+refill+filter. From what I've read it looks like that I'll need to change the water pump and thermostat as well. I don't claim to be an experienced shadetree mechanic, and my enthusiasm for crawling under the car has diminished a bit compared to 10 years ago, but I managed to amass a bunch of tools
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Since Toyota left me with a bad taste it's really at the bottom of my list. Have no experience with Lexus (and its styling is really boring) and I don't know how easy is to work on those (the Highlander I owned had 3 spark plugs located at the rear part of the engine
![Confused](https://www.audiworld.com/forums/images/smilies/confused.gif)
As such, I've been looking at Audi, BMW and Mercedes. Mercs have just too much electronics on them. BMWs I would be the most familiar with obviously, but from I've read, their reliability has taken a dip in recent years with their change from 6 to 4 cylinders. Hence the Audi is currently at the top of my list. If turbo is the only **big** thing that **might** go kaput around or before 100K (as I do not intend to buy extended warranty), I think I'll be fine.
I've watched the FCP video on changing the turbo - not too bad although I'm sure it'll take me 2 days the first time as there are so many bolts to keep track of. Also I wonder whether it can be done without a lift, with the car on jack stands.
Just as a side note, my very first car was a VW Jetta (manual)
Hope I haven't put everyone to sleep by now.
#17
Hi everyone,
I'm interested in purchasing my first Audi A4 (US version, if that matters) and have selected a few years. All the options below have less than 55K on the ODO. Have owned a few BMWs over the years, and a Q7 and done all maintenance on them myself.
So from this list below, which one would you recommend ?
Thank you for your time.
- 2019 Premium S-Line AWD (this has some damage reported on the rear - I can inquire about the incident if this is a really good year)
- 2017 Ultra Premium FWD
- 2021 40 Premium Plus AWD (there are several of these, fresh out of the lease)
The 2021 has a redesigned turbo, it won't wear out like the IHI turbo did.
2muchtorque (07-07-2024)
#18
The 2021 models also have the mild hybrid system which may or may not appeal be appealing. I have the 2021 with DPAA engine and mild hybrid and the operation of the stop start system is much smoother than on earlier cars which use a conventional bendix style starter motor.
#19
MY21+ use Gen4 (aka Evo4) engines (such as DPAA), not Gen3 engines (such as CYMC).
The turbo (two new manufacturers) and the fuel pressure (inc. from 200 bar to 350 bar) are two specific changes for the Gen4 (what VW and Audi are more commonly calling Evo4). The Evo4 is discussed in SSP 683, but I don't know of any English language version on the open Internet. If you know German: https://esperformance.net/ssp/audi/SSP_683_DE.pdf The SSP sure spends a lot of pages on the chains and tensioners as well.
https://www.alexsautohaus.com/whats-...88-evo4-motor/
https://media.vw.com/en-us/releases/1615
#20
"Turbo
One of the biggest changes from the Gen 3 to the EVO 4 motor is the turbos on both the low-output and high-output versions.
Previously, all engines in the EA888 lineup from the 1.8t to the high output 2.0t used IHI turbos of varying sizes.
IHI is no longer the turbo manufacturer for the EVO 4 motor. Instead, the low output versions (GTI) use a Garrett unit, and the Golf R uses a continental.
The IHI turbos used in the previous generation were notoriously unreliable. "
