Anyone have the B9 wiring diagrams, Heated Steering wheel
Old 01-02-2019, 06:04 AM
  #11
JonDeutsch's Avatar
Originally Posted by bruce_miranda
No calibration is required. But you need VCDS or a dealer visit to reset the Steering Wheel angle sensor.
Ah, yes, that's actually what I meant by "calibration." Do we see any issues with a dealer doing the entire install if we're not comfy self-installing?
And what kind of OBDEleven coding is required to handle the stalk button?
Thx.
Old 10-24-2021, 12:13 AM
  #12
emonium's Avatar
Hello! I am searching for the same info as you did)) Have you done this retrofit?? Did you need to use extra wires ??
Old 10-24-2021, 12:21 AM
  #13
bruce_miranda's Avatar
Yes you need not only an extra wire from the dashboard fusebox but you also need a new steering wheel stalk to accept that new wire and send it to the new heated steering wheel.
Old 10-24-2021, 12:29 AM
  #14
emonium's Avatar
I have new steering wheel stalk for heating function allready. Waiting for my new steering wheel now)) Do i need to change connector what goes to steering wheel stalk? Or i can put wires in old connector? How many amps the fuse should be? What kind of wire i should use??
Old 10-24-2021, 12:42 AM
  #15
Check the wiring diagrams. You will need a fuse crimp on one side and the connector crimp on the other side. But the connector is the same.
If you PM me I might have spare parts to make up a harness for you.
Old 10-24-2021, 12:45 AM
  #16
emonium's Avatar
No need, i think i got it ))) But how many amps fuse should be ?? Did you needed to code something ?? Thanks for the reply !!
Old 10-24-2021, 01:04 AM
  #17
There is no coding needed for the actual Heating function but you do need to reset the steering wheel angle sensor. And if you have active steering then that isn't a small job. If you don't then it can be done using VCDS.
Old 10-24-2021, 01:06 AM
  #18
emonium's Avatar
Old 10-24-2021, 09:57 AM
  #19
emonium's Avatar
Last question, but very important. Can you please tell me, which pins i need to power on streening wheel stalk connector... Dont find any info about those pins
bruce_miranda
A4 (B9 Platform) Discussion
240
05-05-2024 11:22 PM
bruce_miranda
04-18-2018 12:07 PM
mwassoc@cox.net
28
09-05-2016 04:09 PM
Kaitlyn2004
Q5/SQ5 MKI (8R) Discussion
12
09-16-2013 12:44 PM
SSLEDGE1234
04-22-2003 10:23 PM
Quick Reply: Anyone have the B9 wiring diagrams, Heated Steering wheel
