Broken MMI after firmware update
Old 05-27-2023, 10:33 AM
Ildpayne's Avatar
Default Broken MMI after firmware update
Hi guys,
I'm in real trouble 😵‍💫 and hope that someone here can help me.
I wanted to update my firmware on my car, in order to update the maps for the navigation.
I managed to install MIB and got the green screen working. I then proceeded to patch the firmware and here is where it went wrong. Apparently the SD card I used was corrupted, and caused a lot of damage to the MMI.
As of now the MMI boots into sdcard media screen and posts no readable media on source, and after 1 minute it reboots, this goes on forever. I've posted images of the screen now and the firmware version I had before it went bad.
As of now, I've installed UART on the unit and have access to it. However I can't boot into emergency.
I've added a couple of logs, if that helps.
I made a backup of the firmware before patching, so I have this, but from here on, I have no idea what to do.
I've found a similar problem on this forum, but the post is from 2021 and the user doesn't seem to be active anymore 😓
Can anyone help?
Thank you in advance.
File Type: txt
File Type: txt
Old 05-27-2023, 06:14 PM
mc-io's Avatar
I would create a GitHub Issue on their repository as you will probably get more help there. Be sure to include the log file: https://github.com/Mr-MIBonk/M.I.B._...le-Bash/issues
I'm sorry I can't be of much help. Good luck.
cc: @bruce_miranda
Old 07-05-2024, 11:22 AM
Backsakki's Avatar
@Ildpayne Did you find a fix for these? I ran into same issue.
Ascari_Blue_A5
Telematics Discussion
17
04-04-2023 09:09 AM
Alex A8 Quattro
10-28-2020 01:22 PM
Charlie327
Audi A3 / S3 / RS 3
03-04-2016 12:47 PM
AxeYrCat
09-02-2002 06:43 AM
Quick Reply: Broken MMI after firmware update
