Comfort Adaptive Suspension Setting
Hi I'm looking at buying an A4 here in Australia and have driven a model with the standard sport (not adaptive) suspension which feels quite good across potholed roads. I was also wondering about getting the comfort (not sport) adaptive suspension but I don't have a chance to drive one so hoping some forum members might be able to help with this question.
If the comfort adapative suspension is in the dynamic mode does this still produce a somewhat sporty damped ride or is it still a bit underdamped.
Thanks
Thanks
I have the Comfort Adaptive Suspension and love it. Around town I generally keep it on Auto, but when I'm on the road - especially if it's a winding road - I put it on Dynamic. A definite difference. Steering feels tighter and there's no question that it accelerates dramatically better. I'm very pleased with it.
It sounds like you're talking about the Drive Select modes, not just Comfort Adaptive Suspension. Switching between Drive Select modes between Auto and Dynamic will adjust the things you mention, but if you want to see ONLY the difference that the adaptive suspension makes the way you'd do the comparison would be to set up the Drive Select Individual mode to match the sub-settings to match another mode except for the one you want to compare. For example I've been driving in the Dynamic Drive Select mode and wanted to see how the Auto mode of the adaptive suspension would be different, so I set the Individual Drive Select mode to use Dynamic for all of the sub-settings except for Suspension which I set to Auto. That way I can switch just the suspension back and forth without changing anything else by picking either Dynamic or Individual Drive Select. BTW, since I've got a manual transmission the acceleration isn't going to change because of Drive Select.
...... so I set the Individual Drive Select mode to use Dynamic for all of the sub-settings except for Suspension which I set to Auto. That way I can switch just the suspension back and forth without changing anything else by picking either Dynamic or Individual Drive Select. BTW, since I've got a manual transmission the acceleration isn't going to change because of Drive Select.
I also have the Comfort Adaptive Suspension. For my everyday commute, I typically leave it in the Individual setting with everything set to Dynamic, except for suspension which I set to Comfort. Toronto roads are terrible this time of year - full of potholes. Not much difference between the suspension modes when I had on my 17 inch winter tires, but it quite noticeable after switching to the 19 inch performance tires. In terms of drive select options, I only bother with Individual (as customized above to soften the suspension on bad roads) and Dynamic. Everything in comfort is just not fun to drive. I love the Comfort Adaptive Suspension for providing this flexibility.
sanfordrich
10
06-11-2018 05:09 AM
bfenster
A4 (B9 Platform) Discussion
11
03-19-2017 09:06 PM
