Dip Stick
Old 08-17-2016, 05:59 PM
  #11
StKnowhere's Avatar
Oil filter and dip stick are front and center.
The engine cover just snaps on, a light tug at each corner and it pops off.
The dip stick stopper simply pulls out. Don't forget to put it back in or you will have a vacuum leak and eventually a check engine light.
The oil filter will drain if you unscrew it enough to break the oring seal. If there is not alread an index mark (green paint on mine) paint a line from the filter to the motor so you know when it is tight. I was able to tighten it by hand to the same position.
The oil filter is a cartridge that snaps into the housing. Since I was not able to verify the part number , I didn't change it this time. It looks like it can be changed without draining the oil.
Use an oil extractor to remove the 5.5 qts. If you don't have one, Google for many options. I use the Harbor Freight Pneumatic Oil Extractor
Old 08-17-2016, 06:15 PM
  #12
StKnowhere's Avatar
Originally Posted by Prof
Which brand oil and what weight oil did you use?
Audi recommends a 0W30, 5W30 or 5W40 oil that meets VW 50200 or 50400 spec. https://www.audiusa.com/content/dam/...e-Bulletin.pdf
The guys who test their oil get good results with Castol Edge 5W40 and Mobile 1 0W40 (European formula), I used the Mobil 1.
Old 08-17-2016, 06:17 PM
  #13
StKnowhere's Avatar
I've been told if you get a dip stick, best to remove it before going to the dealer. They may not put it back assuming it is one of theirs.
Old 08-17-2016, 08:22 PM
  #14
StKnowhere's Avatar
Just stumbled across this Billet Aluminum Oil Filter Housing Hook-Up from our good friends at ECS:
https://www.ecstuning.com/Audi-B9_A4...ine/ES3137378/
Uses a HU 6002 filter.
Old 08-17-2016, 08:49 PM
  #15
yvantheterrible's Avatar
Will be driving from Edmonton to Spokane next week and will do an oil change when I return, thank you for the picture. I too do not plan to change the filter this time around, I only change the filter every two oil changes. Since my first service is covered by the dealer at no cost, I will let them change it.
May try to pick up a few goodies for my A4 while am in the States, that Harbor Freight oil extractor sure looks tempting.
Old 08-17-2016, 08:56 PM
  #16
StKnowhere's Avatar
In case not aware, you do need a relatively high volume compressor ( or accumulator tank) for that extractor. It takes less that 30 sec to reach max vacuum which is enough to evecuate the oil disconnected from the compressor.
Enjoy the drive!
Old 08-18-2016, 09:48 AM
  #17
Prof's Avatar
I will be ordering an A4 for the MY2018. I have an A4 B8 and it is a joy to drive and rather easy to do routine maintenance such as oil changes. For the B9 I was surprised to see that Audi has gone back to an oil filter cartridge. In the B8 the oil filter was a complete unit. I wonder what is the reason to go back to a cartridge oil filter as was found in the A4 B7? When I order my new A4 I will also make sure I buy a Billet Aluminum Oil Filter Housing from ECS.
Old 08-18-2016, 03:23 PM
  #18
StKnowhere's Avatar
Don't know if related but if I understand correctly the recommended oil change interval increased to 10,000 mi.
Old 08-18-2016, 05:56 PM
  #19
You are right, I just like doing my first oil change before that. As STK wrote "not nessesary but fell better".
Old 08-20-2016, 01:15 PM
  #20
adg44's Avatar
Factory fill is 0w30 Castrol.
Quick Reply: Dip Stick
